Page 5 of 5 FirstFirst ... 345
Results 101 to 109 of 109
Thread: Audi A4 B7 2.0TQ | Project Déjà-vu
  1. #101
    Default
    Among other things i received for the other cars, i also received these caps for the A4
    Untitled by mgpdoc, on Flickr
    Audi RS4PRA | VW Golf MKV GT-Y | Audi A1 SportBack
  2. #102
    Default
    Decided to change faces and keep the rear unit it had from factory while having the all new buttons , screes and faces, due to coding issues from the extra heated seats the initial unit didnt have.
    These came in handy
    Oh hi
    No turning back now
    Luckily everything went in perfectly and now it both works as it should and also is new
    In my mind, I am thinking of installing this, at least the rear section of it
    However i cant seem to find the mounting kit for it somewhere among piles of car parts through the years. I asked wiechers the price for a new kit, and it wasnt expensive so i ordered one and received it shortly after
    Surely enough, I knew, that some hours, or days later after receiving the new kit, the old one would magically pop out of nowhere to say hi i am back. And of course it did, lmao.
    Refurbished the fire extinguisher of this car too
  3. #103
    Default
    Then it was time to FINALLY install all the new and refurbished parts i had for the suspension, geometry, mounts, and more.
    Some pics from the process. The pile of parts is in previous post, detailed, and it mainly consists of AC compressor, suspension, all front wishbones and links, all rear wishbones and links, gearbox mount, and 034 Motorport front hub mount, to go with the already previously installed STERN engine mounts.
    Also afterwards a much needed alignment, since nothing was left untouched.
    Also lets not forget, the front subframe swap with the freshly painted one, with solid aluminum 034 mounts installed on it. Such a great product that adds rigidity and feel to the car.
    Out with the OEM
    In with new stuff
    Old one, replaced with new Valeo unit
    Time for alignment for both of them
    Initial ride height
    Then removed some weight at the back
    Also added a Kufatec resistor harness for cancellig the license plate led check light
    Now to see how i will cancel my DRL lights one.
  4. #104
    Default
    Another huge "must do" on my "to-do-list", was to finish the headliner and the rest of the interior that was still white. The plan was to do that first, and then, see how installing the cage, or part of it that is wrapped in alcantara since 2013 for the other car, goes.
    I already had a headliner wrapped in alcantara, but it was only the half front (the back half was chopped off), and also only the front a to b pillars sections. Reason for that, was, that in the other car, only the front part of the cabin would have passengers. Although that might be the case here as well, I wanted the whole headliner done, so using those pieces , was sadly out of the question. I will keep them however for the other A4 and install them there and see how it goes.
    Great, but only the half of it in existence
    So we must make another one.
    Started removing a lot of parts. At this point it is very easy working on interiors, especially on these cars.
    Over some time, i had acquired all the parts of the headliner i needed in black, some of them new, and some used in great condition from S4 B6 and Rs4 B7
    Pillars removed and headliner was next
    Decided to keep the lower section of the rear seats, as it was both light weight, it looks good if done in black alcantara to match the rest of the interior, and also, it allows you to sit on it without hurting yourself as a rear seat delete usually does. And i really do not look forward to that when i install the rear part of the cage.
    Headliner and rear bench out
    Steering column covers
    Shift boot
    Clean canvas
    When I got the call the parts were ready, I was super excited.
    Well that's one way to bring the headliner home
    So let's start assembling the puzzle. Luckily on the A4 if you have opted for the extra folding rear seats, you get to have the ability to pass the headliner through this opening here
    Which trust me is a HUGE bonus, not having to remove the passenger seat otherwise. Ask me how i know.
    In it goes then
    From this
    To this
    Other side
    Buttoning things and clips in place
    Lower section in
    Both in
    Shift boot in
    Bench installed as well
    Some pics of the whole thing
    Hope you like it guys.
    Follow me on instagram, @mgpgarage for faster updates on the project cars, cheers !!
  5. #105
    Default
    Received some more goodies. Among them, there were carbon fiber and carbon kevlar key cover made from the osir original ones, and also the trunk latch plastic cover made in cf.
    Here's a before
    side by side
    Installed
    Also tried to find some seat covers for when the car needs to sit in the shop for some reason, to cover the TILLETT seats.
    These seem to do the trick
    Anothet thing I wanted to try was the fender sidemarkers / blinkers, which come in white from factory. In the past i had tinted them, which looks great with the car theme, dark wheels, and carbon fiber body parts. This time around however I wanted to try amber, inspired by the BMWs of the older era. Like this
    Started with these, which i cleaned as well as i could
    50:50
    All done
    Tried a before and after on my other A4
    Before
    After
    Love how it came out. Will take proper pics of them installed on the 2.0 one.
    Some close ups of the key covers
    There is one more in cf, for an Audi, however still waiting on that to arrive.
    Cheers guys
  6. #106
    Default
    So another thing I wanted to address, that every B7 owner knows about, is the cupholder. Or tha lack of. I mean, yes we have one at the center console, but you have two options. You either use it, and destroy it in some time, or you leave it alone, and decide that the A4 is not a car to drink your beverage in. The end.
    I dont daily the A4, but sometimes, I might. On the other hand, I dont intend to destroy this cupholder, I love it, plus it costs a fortune. What is more, if it breaks, the coffee will go on alcantara, and gauges and at that point, thigs will get ugly.
    So luckily someone saw into that, and made some 3d printed cupholders for an unused space we have below the armrest. Yes, the armrest covers it, but you can lift it, and use it. I also happen to have some R8 / A8 ash trays, and a Q3 one, which fit nicely in there, they look awesome and are extra storage space for little things out of sign. So let me show how it went.
    Bought two, one for each car
    Very good quality out of the printer
    Test fitting things in it
    Installed it on the 20vt car to see how it fits in the console.
    Perfect fit
    Here's how things fit in it
    However me being me, I wanted to trim the upper surface in alcantara to look perfect and match the interior even better. What is more, i took the material and did it myself, which i enjoyed.
    One done
    Finished.
    Looking much better
    No difference in how they fit
    And then in the other car
    Before
    Sorry for the blurry photo
    Just love it
    Cheers guys
  7. #107
    Default
    Nice work! The attention to detail is impressive, as always. The trunk hatch cover in CF made me laugh - in a good way! I would never think to dress that up, hehe. Your upholsterer does great work, too.
  8. #108
    Default
    Quote Originally Posted by Buick40 View Post
    Thank you very much for the good words. Yes, the trunk latch, is something not so ordinary, I agree. One day i opened the trunk and said, hmmm what if i could make a visual continuation of the cf of the trunk to the inside, that would be nice. And so the idea popped up
  9. #109
    Default
    Hello to all,
    So some more updates then,
    First some better pics of the amber side repeaters in the sun
    Love how it came out, seems period correct to me
    new look for the side Quattro badges, visible yet more subtle
    And some better photo of the trunk latch i got some messages about too
    Weighed the car as is now,
    Enjoyed it as a daily
    Got my carbon fiber RS4 front bumper lip
    Came out amazing and very light
    Side by side with the oem one
    Installed
    Labelled my coilpacks for when they go off. A vag guy knows that in advance.
    Bought some supplies for polishing a small Peugeot Sport Rallye 1,3 car
    Came out amazing see it in my my other threads, and also over at instagram @mgpgarage
    Also my cf end caps came in , they look amazing
    They are custom made, and here is how they will be used in my roll cage, where i will use the rear section of it and the front receiving ends will be left open
    From this
    To this
    Like that, snug fit
    Cant wait to install the cage, and also them
    Cheers guys, more to come
    Mike
Posting Permissions
  • You may not post replies
  • You may not edit your posts
