Audi A4 B7 2.0TQ | Project Déjà-vu
  • #46
    So some more things to show you guys .
    First I ordered a 12v plug for the lighter plug, I think it is from an Audi A8.
    Untitled by mgpdoc, on Flickr
    Looks very clean I think
    Then, I had an idea. Why not replace the door blades of the latest A4 with the ones of the other car that were painted and scratch free. Given the chance, I could also clean underneath them, where I was sure I would find some lovely grime, given what i had found during the sideskirt replacement.
    Speaking of the old A4, here is the interior status currently, lol
    Oh well, so, got to work.
    Driver door before
    Used this combo for cleaning
    Cleaned
    Rear driver side door
    Cleaned
    Passenger side door
    Cleaned
    Previous blade
    Super dirty on the inside too
    Whereas the other ones are super clean on the inside
    And also no scratches
    Rear passenger side door
    Cleaned
    Fresh blade
    Used loctite on all the mounting bolts of the blades because I have seen that due to door closing and vibration, bolts tend to go loose over time. Not days or weeks, but months or years. So a little blue loctite prevents that
    When I find some time, i want to replace some tired window/door seals from one car to another
    On another note, rear OEM RS4 B7 fender liners and trim arrived from the dealership
    Will currently keep them in store, because I havent converted yet the RS4 rear fenders.
    Gave a quick clean on the alcantara of the steering wheels of the Audi and the Golf
    Stay tuned, more to come
    Teaser pic. Any guesses
    Cheers
    Mike
    Audi RS4PRA | VW Golf MKV GT-Y | Audi A1 SportBack
    • #47
      Some photos in the sun after the blade swap
      • #48
        Another thing on the list, was to add MP3 playing on the car's capabilities. The soundsystem, although old, is very capable, and at least to my ears, very satisfying. So the options were to go for the RNS-e or add a module that will allow me to play mp3 in the current unit I have.
        The option of the RNS-e is not bad I had already sourced a good unit, scratch free, however it is not so good in terms of maps / navi etc, it is old, that is why, and also, in order to gain the 2nd din space, I need to move the AC unit further lower. However I cannot do that cause I have the custom gauge pod there, where I want to host two new gauges instead of the Defi ones I ran there in the past. Those will probably be a boost controller, and also, a multiple reading gauge from the OBD. All in time though. What I currently decided is that I wanted to keep my single din unit.
        So searching for something that would work, shops in my country found little info, most probably because they didnt want to invest time in it. It is not the most profitable thing I guess. So I came across this video on youtube while searching
        It was on an A3 8P, however unit is the same, so decided to order it. Couldnt go wrong for its cost.
        Received this from Germany
        It had these things inside
        One end of the adaptor
        And the other
        The unit which is pretty good quality
        Card and USB and jack(ipod/ipad) side
        BT, and main power connection sockets
        Headunit removal tools, which i wanted either way, the main cable with the ground, and also jack adapter, basically everything you needed
        Oh and this, which also came handy, I will show you later why
        Before doing anything, tape the console, you will thank me later
        Also add some cloth to the gear knob, cause this is where you will be resting the unit while doing and testing things
        Adapter installed in place on one side
        In order to connect the ground , which is the last thing i did, you need a T8 torx bit, I used this kit
        Worked perfrctly just like in the video I showed before. Veru helpful video overall, except for one part. We are getting there.
        So time to test the card which was basically what I will be using
        I kept getting this reading and the unit did not play music
        I thought, ok we lost some money no biggy. However, I tried further. Still nothing. Reduced the songs and files, thought maybe that was the problem.
        Then before giving up, I thought I would RTFM. That is Read The F*cking Manual for those who are new to this term.
        It clearly says that in order for the unit to read the files, like they would be a CD on the CD changer (6 CDs in there to be exact, so 6 files is the maximum files you can have), you have to name them CD01, CD02, etc. up to CD06.
        So i tried that.
        Boom, it worked. I was very happy with that. It could play as many songs as you liked in there, as long as the files were like that to begin with.
        Yes, you cant see the titles, however you now have MP3, in the OEM unit, and with perfect quality. Also ,the usb works. The other modes I didnt even bother if I am honest.
        So with all of it working it was time to put it all together and pass the module unit to the glove box compartment and make it neat. That was the easy and non stressful part.
        Passing the wiring through
        Used an existing hole which I slightly opened a bit more
        Passing through
        Connection was made , now to mount this
        I wanted somewhere within reach from driver side, and not taking space from the capacity of the glovebox, so . . .
        Heavy duty velcro
        Mounted
        Looks great, but can you see a problem as I am ?
        There is a hole visible from where the wire come through which I dont like. Lets see if i have something in the garage that can fix that
        Boom, clips from the heat and sound insulation of the hood of the car
        Used two of them
        Much better now
        Easy within reach
        And it shows on the screen as it should
        • #49
          And a video of how it works, and the delay it has the first time u turn it on, that reads the music files
          Cheers, I hope you like it guys
          Mike
          • #50
            You attention to detail is inspiring
            • #51
              Thank you very much mate, I appreciate it.
              Cheers
              • #52
                Some things have been happening
                Will update this properly
                Cheers
                • #53
                  Some things got done after I came back from summer holidays .
                  Not in the correct order, but here goes
                  1. Decided to clean the HVAC system of all the cars, so got some supplies from WURTH. I love this company their products do what they say they do.
                  First, AC Cleaning stuff for killing bacteria, disinfecting, etc. You spray with the nozzles inside the vents pretty much.
                  Then, you turn these cabin bombs on, while car is on Air Recycle, and leave it with closed windows. Preferably with noone sitting inside the car at that point as well.
                  Yes I know there are 4 bottles for 3 cars, I used a double penetration for the latest A4, because not only my own DNA is (hopefully no more) inside it.
                  2. Got me some garage stuff
                  --Some sitting and working seats for the garage because the old ones were damaged or tired. These ones from IKEA work perfectly are very comfortable, and affordable.
                  Also great to work while sitting on them and cleaning the wheels.
                  --While I was at IKEA, also spotted some nice dispenser, for QDs, etc
                  not bad and with measuring scale at the side.
                  --Some more Koch stuff which i highly recommend for interior cleaning . They are awesome. Plus a new tyre dressing to test on the left, which seems to work nicely.
                  Finish of the shine foam
                  3. Licence plate frames from Audi
                  Part number is this in case anyone wants to buy them as well
                  Side by side with the one I got in my A1
                  Time to install it
                  Came out subtle and clean, I like it
                  4. Interior and Headlight Canbus (supposedly) white LED lamps
                  These ones are for the DRLs
                  And these are canbus ones
                  They work and look great
                  However they dont do the trick for the check light for lamps
                  This car is very very stubborn in this area. Sadly I will have to install canbus at some point which I **** tbh. Too bored to at the moment.
                  5. RS4 Pedals Installation [PLEASE IF ANYONE HAS A FOOTREST LET ME KNOW PLEASE ]
                  Before
                  Brake on
                  Bit of a PITA to install them when new, but got there with some nice words
                  6. Damaged Door rubber seals
                  Driver door had this
                  Removed the rubber, however these stay behind. At least they did in me.
                  WHAT A PITA to remove these. I was feeling sad for myself while doing it. THEY ARE SO MANY
                  New rubber seal to go in
                  Good
                  No damage now
                  The only other door that has the same damage, is the rear passenger one.
                  However because I will end up changing rear doors (because RS4 swap) i decided to not change this rubber seal at least for now. It is kinda pointless. We shall see.
                  Took some shots.
                  Cheers
                  • #54
                    Then I got another exciting, for me at least, thing that I had ordered from Germany. Something which is custom, and come in CF, cannot be anything but exciting I guess.
                    This is destined for the front grille, unlike the cheap chinese Quattro badges, this is harder to install because it is not flexible, however it looks like a whole different level when done so properly. I have seen it in my buddy's TT and it is amazing.
                    Wanted to give it some depth, so WetSanded it down with this
                    Clear coated with this 2k clear, multiple coats
                    After 1st coat
                    Came out amazing tbh above my expectations
                    Currently waiting for some parts to arrive to start installation process
                    Like this special glue
                    While waiting got the bumper off to be able to work properly
                    Also cleaned the steering wheel cooler from this
                    To this
                    Made a template which will come handy when installing on the Grille
                    And a short video of the finish I achieved.
                    • #55
                      So, in this post I will try to document the procedure of the CF Quattro Grille badge and what it needed to be mounted properly.
                      Because if you recall, it had no mounting points and was just cnc cut cf piece.
                      But first, do you remember the caps on the wheels i swapped from the A4 to the Golf ?
                      Received these
                      And the wheel configuration turned into this
                      Now onto the Grille project
                      Last parts necessary for the project arrived and everything was set
                      Masked everything around and mounted the paper logo i made
                      Then I used the chalk spray to paint and create a shadow where I would make the recess / case for the badge to sit in.
                      Because the badge is not flexible and the grille is curved there needs to be quite some work for it to sit initially and then a very strong specific glue to make it sit in place.
                      Sprayed
                      After having done this, I have to say the chalk spray didnt work well. Neither did it make a really clear line where I would have to use the dremmel, nor did the chalk spray remove with water afterwards as easy as it should have. Probably because it was raw plastic and not something clear coated i guess and the paint bonded somewhat in there. In the end i got it out, but also some words through my mouth. Oh well
                      Out came these
                      Slowly, literally slowly, took material out
                      Testing, marking and then again
                      When i was happy with how deep the recess was, I noticed that the finish was a bit different, naturally where it had been sanded
                      So, I gave it a thin coat of satin black, in the lower part to blend it in. I was stress this might cause the glue to not work as it should, but couldnt accept it looking it like that even though I would possibly be the only one having noticed it.
                      After the light coat.
                      Ready for glue
                      And plenty of zip ties to keep it there while curing
                      Left it like that for 72h although it was an overkill. But I didnt need the car, so why not.
                      The glue literally becomes like a thick plastic. Science b*tch I guess.
                      Used about 1/3
                      Sh*t's about to get real
                      Everything worked perfectly
                      Cat was shocked
                      Test fitted the licence plate to see how it looks
                      Ugly like i guessed it
                      Time to see how it looks on the car
                      I totally love it. Hope you find this nice as well .
                      Cheers
                      Mike
                      • #56
                        Quattro is looking great on the front grill!
                        IG: @sebastienaudeon
                        1974 Porsche 911S
                        Originally posted by TRaNz
                        *pats Sebs head*
                        there there.
                        keep calm, go mash your face on a car window.
                        • #57
                          Thank you ! Now if only I could find a matching CF Audi rings emblem . . .
                          • #58
                            Damn that quattro badge really turned out awesome.
                            Insta Mintyhinrichs
                            • #59
                              Yaaaaaaaaaaas.
                              Cheers mate
                              • #60
                                Received some new orders.
                                1. Some custom plugs for the oil sump which allow for the installation of the temp sensor. I have these made custom in the past, but there was a leak in one of them in the Audi A1 after many years, so thought I'd give these a go.
                                Bought three of them just to put one in each of the running projects I guess.
                                They seem like good quality. We shall see
                                Bought some new clips for the rubber seals at the doors.
                                Never thought clips could cost that much tbh, but oh well.
                                Then I received a thing i scored over at ebay, for a cost of less than 10euros
                                Okay there was some shipping which made this cost almost 20euros, but still it was a nice buy. And when it arrived it looked like new and wanted just a clean nothing more
                                Next to the one from my car.
                                Why did i buy that u ask.
                                The only difference they have is this for the tray to light up with interior lights
                                I swapped parts then
                                And then i made some measurements
                                You see where this is going .
                                Any guesses ?
                                Pack #1
                                Pack #2
                                Cheers, more to come
                                Mike
