Page 3 of 3 FirstFirst 123
Results 51 to 62 of 62
Thread: Audi A4 B7 2.0TQ | Project Déjà-vu
  1. #51
    Default
    Quote Originally Posted by Buick40 View Post
    You attention to detail is inspiring
    Thank you very much mate, I appreciate it.
    Cheers
    Audi RS4PRA | VW Golf MKV GT-Y | Audi A1 SportBack
  2. #52
    Default
    Some things have been happening
    Untitled by mgpdoc, on Flickr
    Will update this properly
    Cheers
  3. #53
    Default
    Some things got done after I came back from summer holidays .
    Not in the correct order, but here goes
    1. Decided to clean the HVAC system of all the cars, so got some supplies from WURTH. I love this company their products do what they say they do.
    First, AC Cleaning stuff for killing bacteria, disinfecting, etc. You spray with the nozzles inside the vents pretty much.
    Then, you turn these cabin bombs on, while car is on Air Recycle, and leave it with closed windows. Preferably with noone sitting inside the car at that point as well.
    Yes I know there are 4 bottles for 3 cars, I used a double penetration for the latest A4, because not only my own DNA is (hopefully no more) inside it.
    2. Got me some garage stuff
    --Some sitting and working seats for the garage because the old ones were damaged or tired. These ones from IKEA work perfectly are very comfortable, and affordable.
    Also great to work while sitting on them and cleaning the wheels.
    --While I was at IKEA, also spotted some nice dispenser, for QDs, etc
    not bad and with measuring scale at the side.
    --Some more Koch stuff which i highly recommend for interior cleaning . They are awesome. Plus a new tyre dressing to test on the left, which seems to work nicely.
    Finish of the shine foam
    3. Licence plate frames from Audi
    Part number is this in case anyone wants to buy them as well
    Side by side with the one I got in my A1
    Time to install it
    Came out subtle and clean, I like it
    4. Interior and Headlight Canbus (supposedly) white LED lamps
    These ones are for the DRLs
    And these are canbus ones
    They work and look great
    However they dont do the trick for the check light for lamps
    This car is very very stubborn in this area. Sadly I will have to install canbus at some point which I **** tbh. Too bored to at the moment.
    5. RS4 Pedals Installation [PLEASE IF ANYONE HAS A FOOTREST LET ME KNOW PLEASE ]
    Before
    Brake on
    Bit of a PITA to install them when new, but got there with some nice words
    6. Damaged Door rubber seals
    Driver door had this
    Removed the rubber, however these stay behind. At least they did in me.
    WHAT A PITA to remove these. I was feeling sad for myself while doing it. THEY ARE SO MANY
    New rubber seal to go in
    Good
    No damage now
    The only other door that has the same damage, is the rear passenger one.
    However because I will end up changing rear doors (because RS4 swap) i decided to not change this rubber seal at least for now. It is kinda pointless. We shall see.
    Took some shots.
    Cheers
  4. #54
    Default
    Then I got another exciting, for me at least, thing that I had ordered from Germany. Something which is custom, and come in CF, cannot be anything but exciting I guess.
    This is destined for the front grille, unlike the cheap chinese Quattro badges, this is harder to install because it is not flexible, however it looks like a whole different level when done so properly. I have seen it in my buddy's TT and it is amazing.
    Wanted to give it some depth, so WetSanded it down with this
    Clear coated with this 2k clear, multiple coats
    After 1st coat
    Came out amazing tbh above my expectations
    Currently waiting for some parts to arrive to start installation process
    Like this special glue
    While waiting got the bumper off to be able to work properly
    Also cleaned the steering wheel cooler from this
    To this
    Made a template which will come handy when installing on the Grille
    And a short video of the finish I achieved.
  5. #55
    Default
    So, in this post I will try to document the procedure of the CF Quattro Grille badge and what it needed to be mounted properly.
    Because if you recall, it had no mounting points and was just cnc cut cf piece.
    But first, do you remember the caps on the wheels i swapped from the A4 to the Golf ?
    Received these
    And the wheel configuration turned into this
    Now onto the Grille project
    Last parts necessary for the project arrived and everything was set
    Masked everything around and mounted the paper logo i made
    Then I used the chalk spray to paint and create a shadow where I would make the recess / case for the badge to sit in.
    Because the badge is not flexible and the grille is curved there needs to be quite some work for it to sit initially and then a very strong specific glue to make it sit in place.
    Sprayed
    After having done this, I have to say the chalk spray didnt work well. Neither did it make a really clear line where I would have to use the dremmel, nor did the chalk spray remove with water afterwards as easy as it should have. Probably because it was raw plastic and not something clear coated i guess and the paint bonded somewhat in there. In the end i got it out, but also some words through my mouth. Oh well
    Out came these
    Slowly, literally slowly, took material out
    Testing, marking and then again
    When i was happy with how deep the recess was, I noticed that the finish was a bit different, naturally where it had been sanded
    So, I gave it a thin coat of satin black, in the lower part to blend it in. I was stress this might cause the glue to not work as it should, but couldnt accept it looking it like that even though I would possibly be the only one having noticed it.
    After the light coat.
    Ready for glue
    And plenty of zip ties to keep it there while curing
    Left it like that for 72h although it was an overkill. But I didnt need the car, so why not.
    The glue literally becomes like a thick plastic. Science b*tch I guess.
    Used about 1/3
    Sh*t's about to get real
    Everything worked perfectly
    Cat was shocked
    Test fitted the licence plate to see how it looks
    Ugly like i guessed it
    Time to see how it looks on the car
    I totally love it. Hope you find this nice as well .
    Cheers
    Mike
  6. #56
    Join Date
    Jan 2012
    Location
    Los Angeles
    Posts
    6,069
    Default
    Quattro is looking great on the front grill!
    IG: @sebastienaudeon
    1974 Porsche 911S
    Quote Originally Posted by TRaNz View Post
    *pats Sebs head*
    there there.
    keep calm, go mash your face on a car window.
  7. #57
    Default
    Quote Originally Posted by SebastienPeek View Post
    Thank you ! Now if only I could find a matching CF Audi rings emblem . . .
  8. #58
    Join Date
    Feb 2010
    Location
    Temple, PA
    Posts
    4,502
    Default
    Damn that quattro badge really turned out awesome.
    Insta Mintyhinrichs
  9. #59
    Default
    Quote Originally Posted by hinrichs View Post
    Yaaaaaaaaaaas.
    Cheers mate
  10. #60
    Default
    Received some new orders.
    1. Some custom plugs for the oil sump which allow for the installation of the temp sensor. I have these made custom in the past, but there was a leak in one of them in the Audi A1 after many years, so thought I'd give these a go.
    Bought three of them just to put one in each of the running projects I guess.
    They seem like good quality. We shall see
    Bought some new clips for the rubber seals at the doors.
    Never thought clips could cost that much tbh, but oh well.
    Then I received a thing i scored over at ebay, for a cost of less than 10euros
    Okay there was some shipping which made this cost almost 20euros, but still it was a nice buy. And when it arrived it looked like new and wanted just a clean nothing more
    Next to the one from my car.
    Why did i buy that u ask.
    The only difference they have is this for the tray to light up with interior lights
    I swapped parts then
    And then i made some measurements
    You see where this is going .
    Any guesses ?
    Pack #1
    Pack #2
    Cheers, more to come
    Mike
  11. #61
    Default
    Teaser of a new mod i pulled of, more for safety reasons, but also, i like how it looks.
  12. #62
    Default
    Some teaser pics of some things that have been done . . .
    More to come
    cheers
Posting Permissions
  • You may not post replies
  • You may not edit your posts
