BBS RS Wheel centers 15" Porsche flat pad with 5x100 pattern faces and waffles
  • BBS RS Wheel centers 15" Porsche flat pad with 5x100 pattern faces and waffles
    Set of 15” BBS RS faces and waffles. Part numbers are (2)RS080, and (2)RS081. Original Porsche 5x130 bolt pattern, flat hub pad. The second bolt pattern drilled is 5x100. 30 hole centers with waffles only. These use large thread(72mm) hex nuts. Great set to build to your specifications. Teal paint has some chips and minor blemishes. Low hub offset hub pad will allow you to build out large lip wheels and still have caliper clearance. Could be double stepped to 16” or triple stepped To 17” as well. $650 shipped to the continental U.S. for all 4 faces and waffles. Fspin720@hotmail.com
    Sent you an Email, Boss.
