97 Thunderbird
The new bumper will be much cooler. Looks pretty aggressive on those new wheels. Most likely you'll need much shorter springs to get it lower thoughE34 build thread link
http://www.stanceworks.com/forums/sh...42#post1613542
Follow me on insta
e_dirty_4
Id like to flush mount a big screen into the dash that is either an android radio, iPad, or has Apple CarPlay.
Here I am using an old double din radio I had to see how it would fit. I don't like it, to much waisted space.
Soundman in cali did an iPad mini in his Tbird and it fits perfectly because iPad screen is 4:3 unlike all other screens I find that are 16:9. taller so it fills the space better. Just not sure if I like the look of having an iPad because its to noticeable that its an iPad.
Removed the carpet and cleaned it using carpet cleaner and drill brush.
Went to the junk yard again and got some small pieces and carpet for the trunk.
Heres my old carpet.
Here's the new one, it had a big rust stain but I was able to get it mostly out.
Found some rust spots under the carpet so I sprayed some rust reformer on them.
I forgot to take a photo of the radio I got at the junk yard to hold me over till I can get an android radio.
I did a lot of research looking at all the different android radios that are available and I found one that I think will work great. Its designed for a KIA but it fills the hole nicely. I printed it to scale so I can see how it would look in the dash.
So I finally got my paint match spray can. The plan is to remove the cladding and plug the holes.
I sanded them down and painted them.
Cleaned it up with a steamer for now.
Put a little bit of silicon on them to make them water tight.
I think it came out pretty good. Its better then the cladding but now I can't wait to fill the holes and paint it. I had to order more plugs to do the other side.
