97 Thunderbird
  • 97 Thunderbird
    Ive been wanting to build a Thunderbird for many years and now I'm finally doing it. I was searching craigslist and found one that had already been manual swapped so I jumped on it.
    Its a 1997 Ford Thunderbird GT4.6 in Light Denim Blue Metallic
    This is what the previous owner already did to the car:
    2010 PI engine
    coil over plug conversion
    Mustang air mass and filter housing and induction tube
    98 mustang fuel injector rail
    Mustang 4.6 GT radiator fan
    Mustang 6G alternator
    Supercoupe adjustable front struts
    J springs on the suspension
    Mustang wheel/hub conversion
    2010 mustang GT wheels
    Clear corner turn signals
    Mustang – GT 150 mph dash gauges
    96 Mustang GT ECU which has been reprogrammed
    Mark 8 front seats Mark a rear seat
    Cobra rear brakes with cobra rotors
    Mark 8 vanity lit mirrors
    My plans are:
    Swap front end from 89-93 thunderbird
    swap rear end from 89-93 thunderbird
    remove cladding on the sides
    make coilovers
    buy wheels with good offset
    clean up wiring that previous owner did
    fix cracked interior
    mold in 8" pioneer head unit
    find Super Coupe center console
    install hand brake
    convert interior to black
    wire tuck engine bay
    exhaust
    cams
    IMG_1676
    IMG_1675
    IMG_1664
    IMG_1701
    IMG_1706
    IMG_1692
    IMG_1691
    IMG_1811
    I did some photoshopping to show what I'm visioning
    8403930-1991-ford-thunderbird-std2
      pulled the seats out and cleaned up the carpet
      IMG_1742
      IMG_1735
      IMG_1745
        Planning on going through and painting all the raw metal parts that ford leaves.
        IMG_1799
        IMG_1804
          just ordered some wheels, tires, and lowering springs. Eventually I will make some coilovers.
          wheels are 18x9.5 +20 offset
          tires are 255/45/18
          and springs are 1.6" lowering springs
          s-l1600
          srth
            Found a 93 in a junk yard to get the parts I need to do the swap. I broke the header panel getting the bumper off oh well Ill deal with it for now till I get a new one.
            Car is going to get worse before it gets better
            IMG_1828
            IMG_1845
            IMG_1846
            IMG_1853
            IMG_1855
              Dope! I always thought these were FWD ahaha. I'd love to see this thing do a burnout.
              𝔣𝔬𝔩𝔩𝔬𝔴 𝔪𝔢
              @𝔳𝔦𝔳𝔢_𝔪𝔢𝔪𝔬𝔯_𝔩𝔢𝔱𝔦
                Thank you, yeah the reason I like the car is because most people won't know what it is. haha but its v8 rwd with good chassis/suspension.
                  The wheels and tires got here!
                  IMG_1890
                  IMG_1918
                    Tried them on real quick before work.
                    IMG_1920
                    IMG_1922
                      Got the lowering springs. side by side they don't look any shorter.
                      IMG_1913
                      First time using a spring compressor, pretty nervous at first but I got the hang of it.
                      IMG_1928
                      IMG_1926
                      IMG_1927
                      IMG_1929
                      Here is before and after, still too high I know but it will have to do for now.
                      IMG_1906
                      IMG_1935
                        This is promising. Super interested to see where this goes.
                          Not sure if this is helpful but I think QA1 has coilovers.
                          https://www.supercoupeperformance.co...ion-chassis-32
                            I had a 1990 Thunderbird Supercoupe in High School. It had the supercharged V6 and a 5 speed. Loved that car.
                              Thank you, yeah I'm probably going to get those.
