Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
Thread: One of a kind yellow E36 Vert cut from a different cloth.. (non M)
  1. #26
    Finally stopped being lazy and got the camber arms in. Adjusted one side roughly to get to how I want it to sit and ran into an issue.
    Untitled
    Untitled
    Added some camber to get the wheel to tuck in and the barrel hit the coilover as I suspected. I already I have a 20 mm spacer on so I'm gonna try and see if a 5 mm spacer will do the trick. If not i'm going to get an inch smaller barrels since one barrel is already cracked anyways.
    Untitled
    Untitled
    Untitled
    Untitled
    In other news, I picked up a MINT original set of OZ futuras for a super steal. I'm not too crazy about them and I basically already have the same wheels so I'll most likely end up trading them or selling if they come down to it. Considered keeping them for my e30 but they're not the kinda wheels I want for it.
    Untitled
  2. #27
    You could get a longer bolt and put a spacer between the trailing arm and the shock, if you need a little more room inwards. Just be sure you get a strong bolt and a thick spacer
  3. #28
    Or less camber, and pull those fenders
  4. #29
    Quote Originally Posted by Graphitemk6 View Post
    Please don't
  5. #30
    Feb 2010
    Temple, PA
    4,376
    Camber totally ruins this one for me, unless this one is being built for a feature like your R32
    Insta Mintyhinrichs
  6. #31
    Haven't really done much to it recently I'm just gonna order the rest of the parts I need and start doing body work by next weekend. Here's some random pics!
    Untitled
    Untitled
    Untitled
  7. #32
    Finally got around to putting the e46 arms on. Just need to tighten everything down and put the tie rods on and the front suspension is done!
    Untitled
    Untitled
    Untitled
    Also test fitted the OZ's (with spacers)
    Untitled
    Untitled
    And picked up a set of Alphards which I'll be using as my daily/temp wheels
    Untitled
    Gonna start working on the rear bumper soon and buttoning up the interior so stay tuned!
  8. #33
    Aug 2016
    N.Ireland (Norn Iron)
    299
    Think the rear camber looks a bit naff on standard wheels but when the Fittipaldis are fitted and the arches are filled it'll look great, Alphards are great <3
  9. #34
    She's on the ground!
    Untitled
    Untitled
    Untitled
  10. #35
    After putting it off for a while I finally decided to start my fog light delete for my front bumper. Started with some plastic weld then filled it up with bondo.
    Untitled
    Untitled
    Untitled
    Filled it up as level as I could then started sanding.
    Untitled
    Untitled
    Just need to sand a little more, fill a little more, sand again and make sure the lines are good then it should be done.
    Also threw the Alphards on. I know the paint is hideous but I got most of it off.
    Untitled
    Untitled
    Love the wheels but mot really a fan of how they look on the car. 18's look super big and bulky to me. Might end up selling them and getting a set of 17 inch OZ's or something.
    FINALLY after months of searching I got my hands on a set of brand new in box Lucid InPro's. Waiting until the car is done and painted to throw them on cause I don't wanna mess them up lol
    Untitled
