hello there, im hoping i can get some help. I have a set of BBS RS2s. I was able to remove all the bolts except for the air valve bolt, seems as if they were stripped from the previous owner. If you didnt know, RS2s come with a hidden air valve that is built into one of the bolts. it just so happened that 3 out 4 of my wheels have a stripped air valve bolt. I know the rest of the bolts are titanium but im not sure if the air valve is titanium as well. Should I swallow the bullet and bring it to a machine shop (trying to keep cost as low as possible) or try with an extractor kit.
here are some options i am considering.
