BBS RGR Diamond Black 17x7.5 5x108
  • BBS RGR Diamond Black 17x7.5 5x108
    For sale I have BBS RGR 717 Rims
    They are Forged | 17x7.5 Et 38 | 65mm center bore |
    Direct fit for many Volvos and in need of a cheap centering ring for Ford ST and RS drivers.
    These are Genuine BBS wheels made originally and only for the Japanese market (this bolt pattern I know they have others!)
    These are new old stock and as such are likely the last that you will find. BBS doesn't list these with 5x108 any more.
    These are light weight coming in a just about 7.7 Kg (17lbs)
    Wheels are a diamond black finish with a heavy silver coating on the front and black painted barrel and horizontal surfaces.
    Every two rims gets original boxes and the metal BBS valve stems
    The rim should clear most brakes. The clearance from the centerline of the wheel hub is as follows. Measure 10cm out and there is 32.7mm of clearance for 40mm. Then it tapers back down. The smallest inner diameter is 194mm either side of the center line at the hub. Diagram available upon request.
    Rims are located in Buffalo NY. Shipping would really not be that bad anywhere in the US.
    $525 a corner for these rather rare wheels. All brand new in box
    Will also entertain reasonable offers.
    Thank you!
    special on the 5 remaining $2500 dollerydoos.
      one set available still
        Bump
          dump
            Still one set available
