Results 1 to 5 of 5
Thread: 1990 volvo 740 battery wiring help
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Join Date
    Dec 2016
    Location
    North America
    Posts
    27
    Default 1990 volvo 740 battery wiring help
    Here is my initial thread for it:
    https://volvoforums.com/forum/volvo-...ng-help-92704/
    Was trying to replace my battery and noticed 2 corroded/damaged positive wires, not sure if im good with removing the whole battery wiring for it or just using the wiring thats there?
    I think i need a new positive terminal + attach the 2 connector tip things which corroded off, so yeah how do i do this (need a step by step tutorial)... lol
  2. #2
    Default
    Cut out the corroded parts for a good length, strip the insulator and resolder same gauge wire with matching connectors. Use thick heat shrink insulator, preferrably with some adhesive, to cover the now exposed parts of wire. You don't want that wire touching your cars body because bad things will happen. Soldering is not ideal, since it can fail again over time due to mechanical/heat stress, but really shouldn't be a problem. I think you can still get those wires from the dealer, but it won't be cheap.
    Your car is very old and you'll need to teach yourself car electronics and general maintenance routines to keep it running, just do some research. 740 with B230FT is a really simple and easy car to maintain.
    As to your original thread, you have 4 connectors to the positive side of the battery, they are used for starter/alternator, cabin electronics etc.
    Good luck.
  3. #3
    Join Date
    Dec 2016
    Location
    North America
    Posts
    27
    Default
    Quote Originally Posted by 8DOM8 View Post
    Good luck.
    Thanks for the really helpful reply man
    Just had a few questions...
    So im guessing i should have enough length for the remaining wiring to be soldered after i cut the corroded parts out right?
    For soldering the crimp/tip things together i'm meant to take the battery wiring out correct, if so how do i do that... would it involve me removing everything in the engine bay to get to the wiring harness/wirings?
  4. #4
    Default
    Quote Originally Posted by 240SS View Post
    After you cut out the corroded parts you'll have to replace the same lenght with new wire.
    You don't necessarily need to remove the harness from your car if there's enough room to do the soldering in the engine bay. If you end up removing the harness, take pictures and label everything before removal so you know where to connect them after the repair.
    Also I think that the end connectors are crimped rather than soldered.
  5. #5
    Join Date
    Dec 2016
    Location
    North America
    Posts
    27
    Default
    So i'd have to replace the corroded parts on my battery wiring with new wiring, how do i do this?
    Sorry again for these stupid questions i've just spent a long time looking around on forums etc. online for help and i can't find the answers to do this...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
