taken from wiki
Quote:
B16B (Type R)
VTEC
Found in:
1997-2000 JDM Civic Type R[EK9]
Displacement: 1,595 cc (97.3 cu in)
Compression: 10.8:1
Bore: 81 mm (3.2 in)
Stroke: 77.4 mm (3.0 in)
Rod/Stroke ratio: 1.84:1
Rod Length: 142.42 mm (5.6 in)
Power: 180 PS (132 kW)180 HP @ 8200 rpm & 118 lb·ft (160 N·m) @ 7500 rpm
as you can see the B18c gsr motor makes 10 more tq and it makes max WHP 1000rpms sooner and max tq 1300 rpms sooner, not too mention that a gsr motor can be had for about 500-1k less.Quote:
JDM B18C
SiR/GSR
VTEC
Found in:
95-98 JDM Honda Integra SiR/SiR II (DB8, DC2)
98-99 JDM Honda Integra SiR-G (DB8, DC2)
Identification: Black valve cover with dual runner intake manifold
Red Line: 8200 rpm
Rev-Limit: 8484 rpm- 8550 rpm (*For some only, most newer model SIR/SIR-G cut off at 8254rpm)
Power: 132.39 kW (180 PS; 178 bhp) @ 7200 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
