Raising an engine
  • WHOSHAUNQ
    Just get yourself a skid plate and scrape the fuck out of it everywhere like I do
    My skid plate was ~1" lower than this at final height.
    it a bad bump with this, your pan is gonna end up smacking the skid plate and cracking. and that looks pretty thin. hasn't bent yet?
  • tomshouse516
    Originally posted by Zic View Post
    when you shim the motor only on the front (depending on how much) it will cause bad vibrations in the drive train.
    You end up with the number 3. if you want to raise the engine, the right way to do it, is also raising the gearbox. so you end up with figure nr2.
    Good luck with the project.
    This isn't entirely true. 1 and 2 are both perfectly fine as long as the pinion and yoke are at the same angle you wont have vibes, that is the purpose of CV/U-joints.
    3 and 4 will vibe, the severity of the misalingment will effect it. A minor amount of misalignment won't cause a major issue usually only a light vibe when accelorating from a stop.
  • sheilaaellis44
    Originally posted by Adam. View Post
    I thought about using washers but I didn't want to attempt something before knowing the facts
    Find a location on the engine to bolt the chain to. The chain is going to go across the engine horizontally, so that it can distribute the weight easily across the chain. Good mounting points include the exhaust manifolds, intake manifold, or the motor mount brackets.
    Bolt the chain to the engine using the 3/8-inch ratchet and socket, and the hardware on the engine. Make sure the chain goes across the engine for balancing purposes.
    Adjust the lifting arm on the engine hoist depending on the weight of the engine. The typical engine hoist has marks for 1/2-ton, 1-ton, 1 1/2-tons and 2 tons. A V8 engine is typically around 500 lbs, so setting the arm at 1/2 or 1 ton is typically a good setting, as you always would rather overdo it, rather than undershoot the capacity.
    Place the hook from the engine hoist around the chain, approximately at the middle. Place the handle from the engine hoist and place it in the jack handle, then pump up the jack. As you lift, the engine will start to elevate. Once it reaches the height you want, you can move the engine as you choose.
  • m3rz
    One of my freinds used the washers from e36 cyl head bolts to lift his engine up. The washers are .25 inches thick. Use 2 on each side to lift your oil pan a half inch.
  • FittedDownLow
    raised motor and full underbody skid plate like an f1 car = jake can stop breaking his oil pan and continue to tuck 16's haha
  • Jesus Christ
    Originally posted by FittedDownLow View Post
    so im thinking if i make 1 inch spacer my driveshaft will **** me
    possibly, try a .5 and if it isnt too bad throw the 1" in there.
  • FittedDownLow
  • LeWagon
    when i had my e30 sedan , my record was 3 sumps in less than 2 months :/ there just to low haha.
  • Adam.
    Nice work! My cars going back to stock height until I can sort things like this out. Sucks to do it but I don't feel like paying for another pan a week after I just bought one
  • TylersEM2
    Where did you acquire this? Or did you make it?
  • projektzwo
    i need to replace my engine pads, but actually they're pretty expensive, also i really need to lift the engine and i was thinking will be unsafe to lift only the engine with no more than 2,5-3cm.. also i want to know what's the best material to use, and can i make them single piece of metal, or i'll need something flexible???
    oh.. and i'm talking about w124 coupe if matters...
  • FunfGang
  • Adam.
    I will do! Just need to find some time to work on my shitty piece of shit bmw
  • CHIF8008
    post pics of what you end up doing adam
  • Jesus Christ
    rwd, awd and fwd all have constant velocity joints.
