cracked wheel, easy to repair?
  • bart taylor
    I have learned that there are a few friends to make in life....one is a good welder, just had a crack welded one of my 19s for 20 bucks
    make sure they drill the end of the crack when they reweld it
  • armandjones82
    If you are still finding some answers to repair up your cracked wheel, try to read it here and see what can you learn from a lot of things to happen up. In that way, you would be able to fix it up and make it all possible.
  • Petis
    crb ras can be dealt with in numerous ways. If it isn't too bad just use a dremel/grinder to level out the rashed area, then use progressively finer sand paper to make it shine again, then buff/polish. Worse rash requires welding and sanding.
  • sixonefive
    Originally posted by Petis View Post
    Should be about $100-$150 at a wheel repair shop
    thanks for the info.
    know anything about fixing curb rash?
  • Petis
  • sixonefive
    started a topic cracked wheel, easy to repair?
    recently cracked/bent one of my wheels, running my spare now, but it looks like shit since its a 16 and my regular wheels are 19's.
    how hard is it to find a place that can fix the crack?
    is it expensive?
    also, would it be expensive to have some curb rash fixed?
    thanks!
