Project: "Last RX-7" by Herblenny
Ahh! Cant wait this this to be finished! The is one of those cars from the early 90's that just doesnt age
January 20th, 2012 - Update from my fabricator's work. Walker Morgan from www.MPFab.com did an awesome job on these parts.
Downpipe
Inside the DP.. you could almost see through..
January 19th, 2012 - Few pics of the update...
Interior.. took the dash out and put just the rebar to hold the steering column in place..
Also installed my Ti Catback
And my MB FD was featured in S3 Mag and they are using one of the photo of my car on their website..
S3 Magazine covers automotive culture, news, & new car reviews. We're allegiant to the spirit of driving & defend cars as more than mobility.
I have a ton of photos of the new set up tomorrow...
I like the manifold, simple execution. I also prefer the top mounts for 20B's as there's much more design freedom when bringing the runners up vs. going down in the bay... however most of our build use 4 or 5" downpipes so there isn't room down low:-/
Curious to see how your dowpipe routes.
January 18th, 2012 - Got my wheels in from WORK Wheels (http://www.workwheelsusa.com/).
WORK CR Ultimate aka Kiwami.
Spec: 18x9.5 +30 and 18x10.5 +23
January 12, 2012 - Last night, I went over to www.MPFab.com to install the 20B back in to the car and get the car ready so that owner of MPfab.com can start building the exhaust system and the V-mount.
Since its important that everything needs to sit the way it is, we needed to install the tranny, ppf, catback, MP, etc... but like always, we ran into other issues..
Issue #1 - Defined Auto kit did not level the engine.
This might be because I had issue lining up one of their motor mount bracket and I had to enlarge the hole in order to get the brackets to slid into the motor. But, that's not it as one of the top hole should of kept the height in order..
Issue #2 - Correcting leveling issue.
We measured everything to make sure if it was the mount or if it was the car. After measuring the chassis, subframe, core support, etc, we came to the conclusion it was the mount. So, we added couple of spacers to see how much it was off..
After adding the spacers (3/8 inch), we had other issues.. which is now the engine was sitting bit to high and PPF was hitting the tranny tunnel. So, we lifted the engine, pull the passenger side mount and cut 3/8 to level it back out. After that, we wanted to make sure if everything else was going to fit so, we dropped the sub frame and bolted the oil pan on to double check everything...
At this point, everything seems ok after cutting but the PPF still seems bit close to the top of the tranny tunnel.
Next, I'm going to bring my AutoEXE braces so Walker from MPFab.com could build the exhaust that will clear all the bracing.
January 10th, 2012 - Well, I would of made an earlier update but I had to put 14 hour day at work yesterday and didn't have much time to tell you all what happened to my trip.
Well, last week I was running around town trying to get my shell ready for a swap with an R1 shell (without sunroof) that a friend of mine had in GA. So, I had to pull the 20B out, get the hatch from my friend's shop (which I was going to paint it and put on my MB FD), find a trailer, and a friend to help me tow it. Because my fabricator does not come in on saturday, I also had to go there day early to pull the car out so I can load it day after.
Saturday morning (Jan. 7th) - We loaded up the car and got to my friend's place in GA. We started taking stuff off of his car and started to transfer to my shell.
During this process, the car smelled really bad and we found some crazy stuff. Like dead mouse
I guess the car was sitting outside for awhile and a mouse made a nice home out of this RX-7.
Since I was going to strip this car to bare metal, I didn't really care about the smell or the dead mouse.... but I did care about what I found next, a bent frame that lead to bent head light assembly mounting points. This is a bad sign as when headlights are mounted and pop ups go up and down, the geometry is messed up so the lights might not line up. At this point, I was quite upset.. Just because I asked my friend to check the car as he knew the car was in an accident before. Also because my car was on hold for 2-3 weeks as my fabricator couldn't cut anything on the shell because of this swap. And I wasted my weekend, other people's time, etc just because my friend didn't take 10 mins to check over the car carefully and to see where the accident was. But he's a friend and he feels bad and going to help me out later so I cant be mad at him.
Anyhow, we loaded the car back up and drove it back to my fabricator.
Hopefully, I'll have more fabrication updates later this week!
January 5th, 2012 - My clutch for the 20B came in today from my favorite clutch company, EXEDY CLUTCH!! Here are few pics
January 4th, 2012 - Happy New Year!!!
Well, not much have been done to the car as I was busy at work... Also, I'm about to trade this shell for an R1 shell without the sunroof. Hoping to do that this weekend.
Anyhow, the little time I had, I stripped out the dash and refinished the rusty metal dash frame.
I sanded it down to bare metal, treated with rust inhibitor, and primed it.
I then sprayed with gloss black then quick shot of gunmetal and clear the whole thing.. Shouldn't rust again
I'm heading to my fabricator's shop (www.MPFab.com) to pull the engine out and get it ready for this weekend's shell swap.
December 30th, 2011 - Not much update on the car... but in a rotary related thing, I had a chance to go see some rare historical rotary cars in Nashville, TN.
Thanks to Founder/Director of Lane Motor Museum, I had a chance to see, hear, and touch some historical and super rare rotary cars.
Here are some pics from my private tour.
1967 NSU Spider - This is the first production rotary car with single rotor, rear mounted engine.
Another Rare NSU Ro-80 - A Birotor sedan
Citroen GS Birotor - I knew about the NSU, but did not know about this Citroen vehicle.
And finally a super rare Citroen M35 Prototype single rotor vehicle... This is the only one in USA.
Well, if i could find one maybe. However ive seen maybe 5 in the last two years on the road in Canada. If anything i'd import it directly from Japan. However, i really love the look of old Japanese cars. I currently own a datsun 720 and would KILL for a 510, so you get the idea! :POriginally posted by Herblenny View PostWhy not an FD
