View Full Version : E34 540i/6 engine work. Progress thread.
Mykk
04-27-2016, 10:51 AM
Heya,
I just wanted to make a little progress thread on my V8 work in my E34 540. I figured I'd make it over in this section instead of the general builds because it's not suspension related.
I do intend to do some suspension mods and bring that ride height down a bit, I even dream of bags some day (maybe not this car). I came very close to bagging my '04 Silverado that instead recieved a mild 2"/4" drop:
http://i40.photobucket.com/albums/e227/mykk/eventscenter1.jpg (http://s40.photobucket.com/user/mykk/media/eventscenter1.jpg.html)
Now on to the BMW:
This here is very much a budget build, with the budget blown out of proportion...Hell,the clutch & flywheel cost more then I paid for the car.
Found the car on craigslist Phoenix Az, non-running. Went down (100 miles from where I live) and checked it out, the only reason I liked the car was for the V8 and manual trans. made a deal, towed it home. it even came with a bunch of fake M badging riddled all over the car that I promptly removed and a set of 18" M wheels (also fakes). I did keep the M5 doior sills though, I kinda like them. Got to diagnosing why it would crank, no fire, occasionally spit and sputter.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/BeFunky_20141105_172229jpg.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/BeFunky_20141105_172229jpg.jpg.html)
Long story short, I found the harmonic damper clocked incorrectly. The crank trigger uses the damper for timing, so it was trying to fire the cylinders way off in no mans land. Re-clocked the damper, it fired right up. Then revealed a bunch more work; engine oil leaks, coolant leaks, power steering leaks, exhaust leaks, noisy valvetrain, smoke out of the tail pipes.
I just kept wrenching away on it, resolving it's issues as they came up. The more I drove it the smoother it was getting. I was also modding and tinkering along the way. After a month of around town driving I then wanted to take it on a real test drive, over the nearest mountain up & down switchbacks.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mingus.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mingus.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/BeFunky_20141226_135210jpg.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/BeFunky_20141226_135210jpg.jpg.html)
The car got a bit hot and then the pressurized cooling system started spewing out the water pump gasket as I got to the top of the mountain. But, otherwise the brakes and steering & suspension and transmission felt great.
Drove it for a year+ before I finally decided to tackle the clutch, which was grabbing at the end of the pedal travel ever since I got the car running.
I opted to pull the drivetrain completely from the car. Clean things up, remove unwanted or unneeded items.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20160218_113041.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20160218_113041.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20160308_133728.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20160308_133728.jpg.html)
While the engine was out I wanted to dial in my own cam timing: Advanced the intake cams +4 degrees and retard the exhaust cams 3 degrees:
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_3705.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_3705.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_3711.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_3711.jpg.html)
Added a set of stainless EBay headers, that..::cough:: needed some persuasion to fit.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_3721.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_3721.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_3722.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_3722.jpg.html)
For being manufactured so cheaply, they sure are expensive to purchase.
But, it's getting there. Slowly.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_3955.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_3955.jpg.html)
For clutch & flywheel I went with Spec. A lightweight single mass aluminum flywheel replaces the OE dual mass boat anchor. As wells as a kevlar full face clutch disc and their stage II 439 ft/lb pressure plate. The Spec flywheel weighs 17.37lbs, the OE dual mass weighs 32.16lbs
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_3959.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_3959.jpg.html)
I also took UUC Motor Werks advice on a fluid blend for the transmission to help keep trans gear lash clatter to a minimum.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_3967.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_3967.jpg.html)
That's where I'm at, with the drivetrain waiting for me to finish cleaning up, painting and modding the engine compartment.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_3980.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_3980.jpg.html)
I've removed the ABS module and am currently making new brake lines from the master cylinder. I've also remove PS pump and hoses and converted to manual steering. I've also remove the dead A/C components.
I have been running a dual 2.5" exhaust, H-pipe, Magnaflow glasspacks as resonators into a Flowmaster Super 10 dumped before the differential.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20150403_170853.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20150403_170853.jpg.html)
Since the headers will need new pipes I opted this time to go with a single 3" full exhaust with tailpipe & tip. Vibrant Ultra Quiet resonator, Flowmaster Super 40 muffler.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_3998.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_3998.jpg.html)
For the computer tuning, I've been running an Ostrich 2.0 chip emulator loaded with my own tuning via TunerProRT. I have also been dialing in an MAFT-PRO that will eventually replace the MAF sensor and be running a form of Speed Density with a MAP, the MAFT-PRO also used wideband O2 sensor feedback for fueling changes. Wideband info supplied by an Innovate MTX-L in the cabin.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20160109_090842.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20160109_090842.jpg.html)
I've also done a few other things that I've wanted along the way. Remove the broke, twisted, & torn original heeeaavvy seats for a set of buckets that combined weight less then half of one OE seat.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/12489281_10201285344651505_2652757086259120501_o.j pg (http://s1230.photobucket.com/user/BassPlayerMykk/media/12489281_10201285344651505_2652757086259120501_o.j pg.html)
(The shoulder harnesses go to the rear seatbelt mounts, not depicted in the photo above)
This here has been my fav mod, because so many BMW enthusiasts strongly dislike it. Making my own grill:
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20150430_191649.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20150430_191649.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20151125_172142.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20151125_172142.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20150430_191534_1.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20150430_191534_1.jpg.html)
Once the car is running on speed density I have a plan for a custom intake.
The "Final mod" (I say that tentatively) is to replace the 2.91:1 open rear with a 3.4x or 3.6x spool
Cheers -Mykk
R2dmax
04-27-2016, 02:29 PM
Interesting, but NOT loving the headlight grill
loekaaz
04-28-2016, 05:16 AM
Well, it's different. Probably must grow on me before I can give an honest opinion.
Engine work is 10/10
Mykk
04-28-2016, 07:41 PM
Really **** seeing my car so torn down, stripped....almost abandoned looking. But I'm making progress, weather permitting. The funny thing about being in this part of Arizona is you can have beautiful sunny 70 degree morning, then 20 minutes later a dark cloud will swoop in and it'll be snowing. ...and hour later, sunny again.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_4004.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_4004.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_4003.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_4003.jpg.html)
Almost done with the engine compartment clean up and paint, at least...good enough for a daily driver non-show car.
I was unable to break the strut to spindle bolts and control arm bolts loose with my breaker bar in my driveway. So it'll be a project once it's in the shop with air tools after a long penetrating oil soak. But, new steering linkage is on and just awaiting a replacement steering gearbox and for me to flare & bend a couple of brake lines before squeezing the drivetrain back into place.
Mykk
05-13-2016, 06:10 PM
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_4046.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_4046.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/IMG_4091.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/IMG_4091.jpg.html)
Mykk
06-09-2016, 10:26 PM
https://www.youtube.com/watch?v=RKb1a19mmYA
loekaaz
06-10-2016, 07:18 AM
Wait. What? No more power steering??
Mykk
06-10-2016, 09:25 AM
Yeah, it's actually pretty easy to steer. Not much different with power steering, only noticeable at a stop but it's not horrible.
Mykk
07-28-2016, 08:39 AM
Still workin on it, although progress is slow as I've had to focus on other aspects of life lately. I did drive it out of the shop on it's own power though.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/13765698_10201998634523306_5168816104845060335_o.j pg (http://s1230.photobucket.com/user/BassPlayerMykk/media/13765698_10201998634523306_5168816104845060335_o.j pg.html)
The manual brake bias valve is leaking, I'm thinking of just removing it from the system completely.
I've gone round and round trying to get my valve covers to seal. II think they are sealing this time but there is a bad oil leak somewhere, or a massive amount of oil collected in the cross-member from previous valve cover leaks and is slowly finding it's way out.
Current To-Do list:
1) Finish wiring front end lighting, cooling fans and tail lights.
2)Remove manual bias valve and bleed brakes.
3) Tuning, Tuning, Tuning.
4) Lowering/cut coils and alignment.
5) Have single 3" exhaust system made.
6) Replace front seats.
7) Repaint car roof and trunk lid.
8)Rebuild differential with 3.64 gears and limited slip from E46 M3.
9) Wash, wash again. Pressure wash. Wax.
10) Install stereo for tunes.
11) Drive the freakin wheels off
MkI
07-29-2016, 11:08 PM
Very interesting build. Love the engine/Tran/exhaust work.
Like others, the grilles a bit different, but if you like it that's all that matters!
Mykk
07-30-2016, 05:49 PM
Back to wrenching. Made a little firewall plate.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mobile%20Uploads/2016-07-30%2011.27.55.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mobile%20Uploads/2016-07-30%2011.27.55.jpg.html)
While I had the engine out and dialing in camshaft timing I marked the dampener with the true TDC of both forward cylinders on each bank as found by a dial indicator on the piston tops. Now that it's running I'm using a spark tester to extend the ignition coil boot in order to clamp on a timing light and dial in the ignition timing to actual crankshaft timing and not theoretical timing from the control tables.
I have a stock tune loaded now to move the car around, at first glance the stock tune has the car idling at 10 degree after top dead center. I can't believe it runs, but I assume it's an emissions tactic to heat up catalytic converters. Once timing is BTDC it should really scream
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mobile%20Uploads/2016-07-30%2013.30.08.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mobile%20Uploads/2016-07-30%2013.30.08.jpg.html)
Mykk
07-31-2016, 11:39 PM
Finally starting the suspension work.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mobile%20Uploads/2016-07-31%2014.27.03.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mobile%20Uploads/2016-07-31%2014.27.03.jpg.html)
New control arms and cutting the coils. I'm thinking of cutting 1.5 coils, but I'm not set on it. Currently researching what that exactly looks like on an E34.
Mykk
08-01-2016, 06:11 PM
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mobile%20Uploads/20160801_101550.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mobile%20Uploads/20160801_101550.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mobile%20Uploads/20160731_192134.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mobile%20Uploads/20160731_192134.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mobile%20Uploads/2016-08-01%2014.08.20.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mobile%20Uploads/2016-08-01%2014.08.20.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mobile%20Uploads/2016-08-01%2015.08.49.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mobile%20Uploads/2016-08-01%2015.08.49.jpg.html)
Before & After:
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mobile%20Uploads/Lowered.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mobile%20Uploads/Lowered.jpg.html)
Although it looks very natural, I really wish it went lower. But, I don't want to cut anymore out of the coil in fear that it may not sit in the strut.
Mykk
08-08-2016, 09:44 AM
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mobile%20Uploads/2016-08-03%2008.29.20.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mobile%20Uploads/2016-08-03%2008.29.20.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/Mobile%20Uploads/2016-08-03%2009.22.52.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/Mobile%20Uploads/2016-08-03%2009.22.52.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20160805_103610.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20160805_103610.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20160805_103752.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20160805_103752.jpg.html)
https://www.youtube.com/watch?v=Q4cg-uNImag
Mykk
08-23-2016, 11:59 PM
Lighting wired up and done: 55w 6k HID's in the fogs, LED clear/amber switchbacks in the corners.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20160822_185510.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20160822_185510.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20160822_195030.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20160822_195030.jpg.html)
Mykk
02-07-2017, 05:40 PM
Still tinkering around with the project car. I decided I wanted to see how the engine responded to an oversize throttledbody. I've had this universal 90mm unit in my stuff for a while, made a plate to bolt it to the M60 intake manifold.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20161218_103343.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20161218_103343.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20161219_125044.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20161219_125044.jpg.html)
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20161224_100516.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20161224_100516.jpg.html)
I've also decided to get to the bottom of the ignition timing and finally find the accurate equation that translates the raw data into crank degrees. In my testing I've found that 75 raw = 10 crank, 87 raw = 20 crank, 100 raw = 30 crank and that x*0.75-45 translates well.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20170207_1416101.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20170207_1416101.jpg.html)
Then I got this idea to convert the TPS over to MAP for load calculations. Wiring a GM 1bar MAP up the TPS wiring and some tuning in the affected load cells the car actually fires up easier, finds steady idle rpm easier and cruises smoother.
http://i1230.photobucket.com/albums/ee488/BassPlayerMykk/20170206_171903.jpg (http://s1230.photobucket.com/user/BassPlayerMykk/media/20170206_171903.jpg.html)
proboner
02-24-2017, 05:31 PM
Honestly kind of like the grille! Something needs to be done about that blank space below it though...
johnjacobj
10-04-2018, 01:22 AM
good work
small business ideas (https://www.bizencyclopedia.com/)
240turbo
12-12-2018, 01:22 PM
When in doubt, go GM sensors! Nice work! You still working on the car? Links for pics don't work.
GloriaFl
05-13-2020, 12:03 PM
you have very cool wheels.
mercv111
09-04-2020, 01:44 AM
Yeah. The wheels are really cool and hot. I loev them from the first view. Thanks for post.
