Need help and advise. Coilovers for Mazda3
  • Need help and advise. Coilovers for Mazda3
    Hello guys!
    I'm completely messed up. I need some coilovers, cause my current setup (Bilsteins + cut Sportlines) doesn't work well with 3.4" lowering that I have now, but I can't find any coilovers that are at least close to that range of lowering
    What is the lowest kit I can get? Thanks for any input!
    Or maybe you know some tricks that help me drop my car to that level but savу it from laying on bumpstops?
    ---We buy parts we don't need with money we don't have to impress people we don't know---
    They're not very good, but K-Sport has coilovers for the 3.
      There are lot of coilover setups for Mazda3. But they are either cheap and crap or too high for me.
        You have cut springs. Doesn't get more cheap and crap than that.
          So what?! You offer me to change one crap for another? I've cut my springs, because I wanted to see how it sits and to realize if I have any issues with rubbing. I always new I would buy some coilovers. And even with cut springs (1 coil cut) Bilsteins work better than cheap crappy coils. But now (with 2 coils cut) they are overlowered and do not work at all, laying on bump stops.
            Stance GR+
            "Pavement Eater"
            WFC #1913
            Stanceworks Feature
            http://www.stanceworks.com/?p=8665
              Originally posted by ILLES13 View Post
              Stance GR+
              I know they recently produced a kit for Mazda3, but it still has several issues.
                KW or H&R?
                A lot of people like these on the Focus (we have very similar suspension setups with the Mazda 3 chassis I think). I have the H&Rs and love them.
                  Stance GR+
                  The stance kit for these cars is like a unicorn. Some people claim to have it but who really knows.
                  JDR and I have been knocking around ideas on what to do for awhile as we both have similar goals (he wants to get low and stay off bump stops, I want to get low without removing rings/cutting shit).
                  I bought BC's hoping to get lower than my last sport line setup and got the exact same fucking height.
                  So I am trying to order new (shorter/stiffer) springs from them but getting a bit of a run around.
                  H&R/KW seem to be the front runners in getting low right now. Hacked K sports aside.
                  Edit: BC got back to me the R&D dept is trying shorter springs in they mazda units and seeing if it works (and by works I mean doesn't bottom out the shock).
                  I like em dropped.
                    Um. Yeah, pretty much. Even K-Sport is miles ahead of cut springs and laying on bumpstops.
                      Here is the answer from BC-Racing NA for my inquiry: "The lowest we can get the Mazda 3 is a 3" drop". I asked them how they gonna achieve that range of lowering. Awaiting for the answer.
                        Ya don't know if you saw my last message but they are going to get back to me monday bout the shorter spring.
                        Here is what they said
                        Dave
                        Not yet I will see if I can get something sorted out by Mon. We will be doing a test fit btwn now and then to confirm there will be no issues.
                        Mike
                        JDR can you measure from the bottom of your front fender arch to the ground when you have a chance?
                        Mine is 24inches.
                        I like em dropped.
                          Mine is 24inches.
                          Mine is 23.6 How can that be?
                            well, you are lower than 2 people on BC's and 1 person on tiens.
                            The 2 other people I have asked are 24 as well.
                            (This all assumes correct size tires and what not)
                            I like em dropped.
                              Yes, but I thought I should be more than 0.6". It seems I messed up with inches/milimeters transfer. As far as I get -1.8" Sportlines with 2 coils (0.5" each) cut my current lowering is only 2.8" but not 3.2 as I stated before.
