Preload
  • Preload
    I need less travel in my coilovers so I don't rub so bad. If I increase preload a lot will it help? Or do I need to spend the money on higher spring rates?
    bumpstops are your friend.
    Widebody B6 build
    HIT ME UP if you need Ksport supplies. i can get them to you cheaper than anyone.
      What is the best place to order bumpstops from. I have megan LP series coilovers on my IS300.
        you might want to try a higher spring rate.
        depending on the car bump stops might not help much !
          Just buy stiffer springs. Adding a bunch of preload or riding your bumpstops around all the time is pretty damn ghetto.
            Does anyone have a spring company they recommend?
              what type of spring are you running now ?
                They are just the ones that came on the coilovers through Megan and are 10kg/mm up front and 8kg/mm out back. I was thinking of running 16kg/mm and 14kg/mm.
                  Swift makes some nice springs for coilovers as far as I know.
                  Swift Springs USA | The Science of Winning
                  ---We buy parts we don't need with money we don't have to impress people we don't know---
                    this
                    I cut my bump stop to increase travel, but I would never get rid of it
                    that's asking for trouble
