kill switch help!!
This topic is closed.
  • kill switch help!!
    problem solved.
    iLevel goes into a standby mode after 24 hours, and should not drain your battery. A kill switch should not be necessary.
    If you're intent on running a kill switch for your management, a standard SPST toggle triggering a relay on the red wire from the battery to the e-Level ECU will remove all power from the system.
      lol thx for the edit
        I figured I should probably try and be nice for once.
        It is a fucking rats nest, though
          went cheap on layout so dont really matter cauze daily...
          can always change it up later
            up, more advice/help needed thanks
              UP?
