So for my fikses i have 5x112=>5x100 adapters...
the front ones are some special 15mm adapters from germany..i dont want to ruin them cause they're "supposedly" worth quite a lot...(theyre DOT approved from europe..and i know its not called DOT, ive been up for like 50 hours..give me a break)
the rear ones are regular 18mm adapters..
my problem is...
1) i want to run 15s in the back too, but i dont want to buy new ones...id rather have my old ones shaved down 3mm's...but the studs are pressed on the adapter, so this causes a problem..has anyone had any experience with this kind of work? I heard if i got the studs pushed back out, it might take some of the aluminum with it...
2) the expensive german adapters, their lugs are 14x1.5 and not 12x1.5...any way of changing this? Again the studs are pressed on.
Thanks
Car in question.
my problem is...
Thanks
Car in question.
