Mercedes 190e w201
  • Mercedes 190e w201
    Hi how are you guys?
    Need some info. Cant find a decent set of lowering springs for my mercedes.
    Id like to cut my springs not sure of how many coils to chop off.
    If anyone did so on the same car please would you post pictures of your ride and how many coils did you chop off
    If you're using stock springs, i'd say start off with 1.5 coils and then slowly cut it by .5 increments until you have the height you desire.
    If anything you shouldn't surpass 3 coils ever.
      your going to need to cut about half/ 3/4 the spring to be dumped. These springs are under incredible pressure. Be careful when removing them.
        Not sure where I saw it, but there are adjustable springs for that too. I'll try find it if I can.
        product recommendations
          Go to 190REV.net. There are threads all about this specific to the 190. I get a lot of info for mine there
          progress IS a slow process
            This is with lowering springs 2.5 coils cut up front and 3 in the rear. my buddies car we cut about 3.5 front and back and its a tiny bit lower. Just cut a coil put it back in see how it sits and go from there.
            1958 Chevy Apache shop truck build
            Commonwealth
            W201/W124 Control arms and bag brackets
            http://www.commonwealthmotoring.com/
            Air ride and custom parts
            IG - Commonwealth_mf FB - https://facebook.com/commonwealthmotoring
              SO you cut that much from the Lowering Spring? What shocks are you running?
                Yea cut that much off the springs. Still on stock struts, but when I bag it I will be running e36 struts in the front and saab 900 in the rear.
                Commonwealth
