So I have installed my Autopilot V2 system on my 2006 VW GTI, but I am having trouble finding out where I need to tap my Ignition Source into??? I have tried tapping it into the Horn/Radio/Turn Signal fuses in the engine bay Fuse Box, but the controller stays on 24/7 preventing the rise on start feature. Do I need to re-route the ignition wire through the firewall and back into the cabin fuse box?
On top of that, when I go to set my presets, it won't let me. I set the car at the heigh I want, I hold the button down until the edit screen comes up, then I press the 1+5 buttons to exit. After I double tap it, it says, "Not Calibrated".
I got the system used, so there were already some presets in it. The All Down preset that was in it works fine, but none of the others do... just says "not Calibrated". A person at airlift that i talked to today said to fix my ignition source issue first, the re-calibrate the car.
I can control everything manually just fine.
Any help for this newb would be really helpful, and greatly appreciated.
