So after having my air installed for over a year, I finally got around to installing my e-Level sensors. I followed all the instructions for installing the sensors. They have a little less than the 2.75" of travel recommended, probably around 2.5" and definitely greater than 2". When running the manual-range calibration, my car airs out then does not do anything else. After a bit my rocker switch flashes both arrows rapidly.
This error says that the travel range is too small which I find hard to believe. The only thing that I can think of is that the rear fills and dumps much faster than the front. I'm not sure if this would cause a problem.
If anyone has any insight that would be greatly appreciated. I will contact AccuAir monday, as I assume they don't work on the weekends.
Thanks,
Mike
Thanks,
Mike
