I'm putting my first air ride system together and had a question about analog setups. From the videos I have seen, it looks as if analog setups are either at an "up" or "down" position. I have seen how to hook the valves up and I understand the wiring. My question is: is there a way to set it up so you can hold the button for a desired height? I don't want to be riding at 4x4 status and drop it to the ground when parked. I'd like to ride it low, and drop it lower parked, and only raise it for large bumps.
TL;DR: Are all analog setups a quick fill/dump, or can I slow the fill speed?
