Fender Rollz
  • Fender Rollz
    Hi there,
    i recently bought some spacers for my '95 BMW e36 coupe. I'm looking for some threads
    or DIY Tutorials or something which can show me how far i can roll my fenders.
    The situation to start with:
    Specs:
    Rear 18x8.5 ET10 ( original ET50 with 40mm spacers)
    Tires: 215 / 40 / 18
    I hope u guys can help me out! Thanks in advance
    #SCHTAAAAAAAAAAAANZ
    Anyone?
    #SCHTAAAAAAAAAAAANZ
      Would be better if you use 25mm spacers/adapters instead of 40mm, and just roll the fenders to fit. You'd barely need any pull at all.
      - Bagged '98 Chevy S10 - Stock '88 Volvo 240DL - Broken '87 Mitsubishi Starion ESi-R - Also Broken '87 Shelby Lancer #707/800 -
        No examples so far?
        #SCHTAAAAAAAAAAAANZ
          Wont 40mm spacers kill your wheel bearings?
            No.
              you can flare that no problem. to fit
              doing it for the internet and the scene kids.
                You will need the tool that I just bought.
                Wheel Arch Roller
                  Yeah, a buddy of mine has one of these laying around in his garage so that won't be a problem. Does anyone have examples of the max amount of stretch?
                  #SCHTAAAAAAAAAAAANZ
                    Heat the fender up so it's just about hot to touch and slowly roll. Clean out the material on the inside of the fender first and scrape it all out. These fenders are super easy to roll and pull if you do the prep work and remove the sealer inside the crease
                    1982 euro porsche 930 turbo
                      Thnx for the tips man, i will try it out a.s.a.p
                      #SCHTAAAAAAAAAAAANZ
