BBS RS 157&158 16x9 front and rear. 5x130 faces and barrels are currently Nogaro Blue
Fronts: 2" lips, 6.5" barrels. ET44 20mm adapters put the final offset at 24.
Rears: 2.5" lips, 6.0" barrels. ET32 30mm adapters put the final offset at 2.
Bolts are real deal 24karat gold plated. 1/2 height caps with chrome center caps.
Adapters are Adaptec. 5x100 - 5x130. I am running a 15mm on the right and 20mm on the left in the front because my car is slightly off. If somebody buys the whole setup I will get another adapter of whichever you want. 15 or 20. Rears are 30mm
Tires are Falken 512's. 205/40's Rears are in great shape. Plenty of tread left. Fronts are worn. Definitely good for at least a season, maybe more depending on how much you drive and or do burnouts. Haha.
$2800 for everything painted whatever color you want.
$2500 as is.
$2500 as is.
