Putting up my wheels for sale since they were going to be temporary since the beginning.
3-piece BBS Motorsport e28's
Front 18x9.5 et 49 Falken 215/40 512s with at least 80%
Rear 18x10 et 54 Nitto 225/40 Neo Gens with at least 80%
2" lips all around. 7.5" & 8" barrels
Porsche 5x130 and centerlock option
Magnesium centers painted gold (not perfect but isn't crazy noticeable) and barrels are painted black
They have new black anodized inserts and BBS bolts. The wheels need a little cleaning but it's nothing some soap and water will fix.
The bad
Once face doesn't match the rest and has a crack around a spoke, neither are noticeable unless someone that knows about it points it out. Best solution would be to find a pair of E28 faces and replace the fronts but they're fine to drive on. I dailyed these wheels.
The front seals should probably be replaced or you can just use rtv since they have a slow leak. I put air probably once every two days.
I used 20mm adapters on my mk4
I'm asking 2900 shipped obo
Before new hardware and tires
One of these faces doesn't match but it doesn't affect offset
I can get better and closer pictures if wanted. Thanks for looking
Pictures of the cracked spoke
The bad
