Starform Type D 16x9 +15 | 16x8 +8 wheels and tires, 4x100 adaptors.
Set of rare JDM Starform D Type Rim, Staggered set up, good tires, original Starform center caps, great condition, rims are 3 pc construction, and Made in Japan.
No dent, no cracks, never repaired, no curb rashes, ALL original. There are blemishes (from storage- stacking rim on top of each other, usage- small chips) as these are used wheels that are over 15 years old! These are in great shape.
5x114.3
Center Bore 72.5mm
2x 16x9 +15
2x 16x8 +8
Dunlop Direzza DZ101 205/40/16
$900.00 wheels and tires
If you want to put them on your 4x100 car. I have a set of custom made adapters. The adapters were made to specs with the intention to use on an e30 but will work with any 4x100 car. Adapters are in great condition. Made in USA.
Adapter specs:
4x100 to 5x114.3
Hub Centric
18mm Thickness
All the correct hardware
$225.00 adaptors
5x114.3
Center Bore 72.5mm
2x 16x9 +15
2x 16x8 +8
Adapter specs:
4x100 to 5x114.3
Hub Centric
18mm Thickness
$225.00 adaptors
