was hoping that something could be done to allow for searches to include 2 and three character terms. chassis models and engine codes, things like that get overlooked. just hoping there some kinda fix by the powers that be. cheers
search parameters
most forums i've been on are like this it seems. Google does a good job of searching 2 or 3 letter words however.
it is poopy since most cars have a chassis code or chassis nickname they go by
if you wish to search the forums you can use the google site specific search function.
in this case you would want to type in:
site:www.stanceworks.com/forums/ "what you're searching for"
this will limit all results to the stanceworks forums. each forum is different so you might have to mess around with the site specifics, like if you leave out the last / or add .php at the end, the search might not work correctly.
hope that helps
