Guys i have two broken springs on my contour i need to replace them bad does anybody know if ford escort springs will fit on my 4 banger contour?!?!?!?!?!?!
98 fLord contour help!!
No, no they won't. If I were you I'd just go to the nearest junk yard and pull the whole spring strut assembly's and replace them that way. You didn't specify if it was the front or back. If you have two front springs broken you're in for a little work. Removing the strut/spring assembly on the front is a bit of work. The rears are easier. Getting the strut out of the hub assembly takes plenty of liquid wrench and elbow grease. I had a 96 that I lowered and added rear discs to. Go over to contour.org and poke around.
What he just said. I used to own a 99 SVTC. Contour.org is THE spot for anything Contour related.-Alex
'97 DC4 - GS, Green on Old Man Tan. Low as poop, loud as Farooq
20140817_194828 by Alexander D.24, on Flickr
