So I bought a car with accuair e-level installed. The guy had a lot of audio and the air management was installed horribly. It was very finicky to say the least. Well I re-did the air management and have it set up for testing right now before i finish my trunk.
I can not get the controller to work at all. It used to work sometimes. But now nothing will respond. I know 100% that everything is wired correctly as this is not my first car on air. Thought it could be a bad ground so I installed a grounding block to my chassis and still nothing. Thought the keyfob addition could be messing with it, so I bypassed it and still nothing. Any suggestions? Is there anyway I can check if the ecu is dead? cause thats the only thing I can think of... I know the relay works cause the compressors have kicked on before. And it is getting 12v in appropriate locations. HELP
