SOLD.
I came across an e38 that I would really love to pick up and in result I am going to try and move my car fast. I realize this is about $1500 more then the book value on these cars right now but once you read the list of maintenance on the car and learn a little bit about it you might find that its a better deal then its 150k $5,000 counterpart. First I'll start by saying that I was trying to sell this car last year with mparrs on it for $9500. This year I've only done more work to the car and can't say that I know of very many issues with it. This is the perfect car for someone who wants a nice modded e39 but doesn't have much cash. All it needs is a nice set of wheels and its ready to roll.
Pictures are from last year on mparrs. Its now on 16inch Borbet winter wheels but will most likely be sold on a set of style 32s with good tires. Everything listed below is included.
Exterior:
•Boser Hood (Stock Hood - Metal Extension)
•Shaved Roundels
•Custom Flared Fenders
•Custom Flared Quarters
•DDM e39 M5 Front Bumper w/fogs
•Hella Headlights
•Hella Euro Amber Celis LED tails with Ballast retrofit (done the correct way)
•OEM Euro Decklid
•6k Low beam HIDs
•6k Fog HIDs with code canceler
•Shadowline Trim
•Authentic AC Schnitzer Sport mirrors
•Full re-spray performed August 2008 by www.TSAutoBody.com in Massachusetts (well over $5,000 with all the body work that was involved)
Wheels/Tires:
17inch Style 32s
16x7 Borbet Winter wheels
Interior:
•Custom Brown Suede Headliner (all pillars, sunroof cover, all handles painted black) (I can include the full original tan headliner with everything in mint condition if someone doesn't like this mod)
•e46 ZHP Shift knob (also will include burlwood 6spd bavarian shift knob)
•Rear Side Shades
•Rear Electric Shelf Shade
•K40 Stealth Radar Detector front/back
•BMW Rubber All-season Mats
•Rear Cup Holder Delete
•E39 m5 cluster rings and needles
Audio (DSP):
•Infinity Kappa 5-1/4s in front
•Infinity Kappa 5.1 Tweeters in front
•Infinity Kappa 5-1/4s in rear shelf
•Prewired for LOC Converter for RCAs
Performance:
•Magnaflow High flow cats
•Magnaflow Muffler
•Resonator Delete
•Bavauto High Performance Ignition Coils
•Superchips chip and ECU re-flash
•Rogue Ultimate Short Shifter
•K&N Drop In High-Flow Air Filter
•Zechenhausen CDV delete
Suspension/Brakes:
•Fk Silverline Coilovers
•Zimmerman Cross Drilled Rotors
•Aekebono Pads
•Stainless Steel Brake Lines
Things that were done since I bought it:
•Sachs Clutch
•Dual Mass Flywheel
•Slave Cylinder
•Water pump
•Fan Clutch
•Valve Cover Gaskets
•Valley Pan Gasket
•Rear intake valve
•All intake gaskets
•Radiator
•Thermostat
•Control arms (front and rear)
•Sway bar links
•Tie rod end links
•Any Misc Bushings (front and rear)
•Cross Drilled Rotors (front and rear)
•Akebono Pads (front and rear - no dust )
•02 Sensors
(Within 4k):
•New Slave Cylinder (done at 199k)
•All Fluids replaced (at 200k) - Brake, Oil, Coolant and filters
•New endlinks
•New lower control arms
•New Lower Oil Pan and gasket
•Expansion Tank with new Shroud
•Accumulator Pipe Seals
•TCS cables
•Both Cooling Hoses
•Power steering lines
•NGK Plugs
•New Cabin Filters
•Shifter Bushings
•Original Alternator was removed and rebuilt
•Original Starter was removed and rebuilt
I know for 100% that I am forgetting a few things. The car was in a fender bender in NYC and was repaired without the replacement of any original panels. The rear bumper was replaced, and one taillight had to be replaced. The trunk was repaired but is still original. I've included the one photo I have from the body shop so you can see the quality of the paint work. I can also provide a few from the accident so any interested buyer could see the damage (along with a receipt of what was done to the rear – the car received a full re-spray on top of that). In my opinion, you will not find another example as clean as this 540 anywhere. I realize the mileage is high but for the work performed (all notorious issues these cars have been addressed) I don't think the $3,000 extra I am asking is much. It books in the $9,000 range in good condition on KBB. I consider this car to be excellent minus a little wear on the driver’s seat and a few hiccups.
The bad:
•Needs AC fan
•The undercarriage has some dings and dents from being low (nothing that affects driving, alignment, and nothing is bent in the suspension)
•My sister drove it over an island and scratched the bottom of the right rocker.
•Cruise control has some strange issue with disengaging (I can provide all parts needed to repair)
This is the most recent picture I have of the car. It was about a month ago before I took my winter wheels off:
More pics and a few interior shots. Sorry the weather has been terrible. When it improves I will take pics again and clean the car.
Interior:
The Schmidts are NOT included in the sale of this car.
Exterior:
•Shaved Roundels
•Hella Headlights
•OEM Euro Decklid
•6k Low beam HIDs
•Shadowline Trim
Wheels/Tires:
17inch Style 32s
Interior:
•Rear Side Shades
Audio (DSP):
Performance:
•Magnaflow Muffler
•Resonator Delete
Suspension/Brakes:
•Aekebono Pads
•Sachs Clutch
•Dual Mass Flywheel
•Slave Cylinder
•Water pump
•Fan Clutch
•Valley Pan Gasket
•Rear intake valve
•All intake gaskets
•Radiator
•Thermostat
•Sway bar links
•Tie rod end links
•02 Sensors
(Within 4k):
•New endlinks
•TCS cables
•Both Cooling Hoses
•NGK Plugs
•New Cabin Filters
•Shifter Bushings
The bad:
•Needs AC fan
Interior:
