This Public Service Announcement is brought to you by me.
When you are setting up a water trap in an air suspension system the reason for doing so is to trap water/particles before it goes into the valves, which can cause them to become faulty/fail.
Almost 85% of the setups I see, people put the water trap in between the compressor and tank. THIS IS 100% WRONG!
An air compressor over time generates heat when running for an extended amount. That hot air passes through the water trap and into the tank. Due to magic and witchcraft, when hot air becomes cold in certain climates, its causes condensation which builds up in the chamber of air aka tank.
Water traps should be located after the tank, before the valves, that way any condensation in the tank is stopped before the valves. It also doesnt hurt to put a check valve aka one way valve after the water trap, before the valves, incase of loss of tank pressure. that way it will assure you the car will stay in the air so you can drive to rectify the issue.
Again, the PSA has been brough to you by your friendly neighbourhood Oxer.
