Im driving a 1969 Datsun 510 4dr. sedan. Im currently on coilovers all around, but have decided that Id like to make the plunge (no pun intended) to get even lower. Im having some trouble figuring out what to do about the front suspension in regards to fitting up some sort of air suspension. Its a Macpherson strut system with basically all suspension connections going to the hub and the top of the strut goes through the strut tower. As you drive, all flex is transferred to the strut assembly. If you remove the struts to add in an air bag, that bag will now take all for the twisting and flexing directly.
Id rather not go to an air canister type system if I dont have to, as Id like the ride quality of actual bags if possible. Ive been thinking of creating some sort of upper control arm to stabilize the upper section of airbag strut, but that would be quite a job...
Curious to know if any of the more knowledgable guys out there have any suggestions.
