NEW PRICE $1400 (local buyers only!!)
Specs:
Front: 17 x 8 ET37 - 1.5" lips
Rear: 17 x 9 ET24 - 2.5" lips
Tires:
Front: 235/40/17 Falken FK 452
Rear: 235/40/17 Falken FK 452
The tires have about about 1000 miles on them. Still a ton of tread left. The rears have rubbings marks on the sidewall from when I first mounted the tires.
I also have a set of staggered/stretched tires that were originally on the wheels when I purchased them. I can have the tires swapped for you if you would like. These also have plenty of tread left and are relatively new.
Front: 205/40/17 Falken Ziex 512
Rear: 215/40/17 Falken Ziex 515
Fitment:
I was able to fit these on my E36 with no fender work done when it had the staggered/stretched tires on it. Now that I am running more meat, I had to have the rear slightly rolled.
The offsets and widths are absolutely perfect for a more aggressive fitment on E36s and E46s alike. E30 M3s will have to run a spacer in the front (which I can provide) but the rear should clear the struts fine.
Finish:
These wheels have been refinished within the past year. They were in very good condition when I received them. The clear from the lips have been stripped and sealed after they were mirror polished. The sealant has meant that I haven't had to repolish the wheels since they were assembled and after every wash they come out looking as good as they did the day they were first mounted.
The faces are smooth to the touch and do not retain brake dust (a sign of a porous clearcoat). The finish is resilient to daily wear but chips just as easily as OEM painted wheels if you're not careful with your tools during mounting and dismounting.
The wheels are very well sealed and the pressures of the tires haven't dropped since they were mounted nearly 3 months ago.
This one is with the 235s mounted
I can go into further detail over email or PM (if I am allowed to with this being my 1st post). Also can send more pictures for serious buyers. I'd prefer a local buyer in Southern California and I am also open to trades.
Asking price is 1800obo.
Specs:
Tires:
Fitment:
Finish:
