Help me I.D. my spring rates (pics)
  • Help me I.D. my spring rates (pics)
    Reading threads about spring rates made me wonder what mine actually are... jacked up the car and took some pics. Can you guys I.D. my spring rates for me?
    Thanks!
    Rear:
    Front:
    "Auto Detailing by Jake," servicing the Southern California auto enthusiast community.
    Detailing Dough --> College dues. Which leaves $____ for e36. D'oh.
    Less than 650 lbs, I think that's when Eibach starts labeling the spring rates right on the spring. I am not sure if you can take those serial numbers and ask them what your rates are, but it's worth a shot.
      Your rears are 7" tall with an 2.25 ID and 450# spring rate if I am reading it right.
      And the fronts according to a google search are 6" tall with a 2.5" ID and 300# rate.
      ShakotanOscar.blogspot.com
      Fabulous Street Scene
        sweet. thanks a bunch!
        I guess I am going to need stiffer and shorter coil springs if I'm going to get some wider spacers... any recommendations? I'm on bilstein sport shocks.
          they are all labeled. you have to know what you are holding :P
          id be weary of going shorter than 6" on the sports. if you are trying to go with a spring shorter than 6" in the front, you will be very close to bottoming out on the front struts. you could probably get away with a 6" spring in the rear and have a little travel left. ive tried a 5.5" spring in the rear and the bilstein shock was almost fully collapsed, although it was on an adjuster to raise it up some. if you are going with a spring rate greater than 450, id suggest looking into getting them revalved and shortened, if you want some controlled damping.
          Originally posted by Kielan
          I've had a lot more fun in my Dad's Prius than I care to admit.
          BMW e23 build Thread
            I learn something new everyday
            ...The more you know.
              Who revalves and shortens shocks? I've never delved into this area... are there local shops that do such work or would I have to send them back in to bilstein? Any special amount of shortening / revalving I need?
                yes, competent race shops that offer those services should be able to do it. bilstein offers the service for rebuilds for $65, iirc. not too long ago, there was a front set of bilstein struts going for $300, on bf.com race classifieds, valved for springs up to 700lbs/in. what i would do is probably look at what your ultimate goal is and determine if its worth doing or just go with a coilover setup that uses a shortened housing with an insert. (ie ground control or the like)
