Acccuair VU4 Manifold harness too short?
This topic is closed.
  • Acccuair VU4 Manifold harness too short?
    Hi all
    Fitting my accuair system at the moment but the vu4 harness is very short meaning I can't mount it on show.
    Can the harness be lengthened, cut and solder in longer cable?
    Thanks.
    Ben.
    Anyone?
      I don't see why not. Just be careful and make sure you know what you're doing.
      I dislike Byron.
        yes, you could cut and lengthen that harness easily.
        build thread?
          It's not going to effect the speed of the valves? Resistance increase and that?
            I dont think the system is sophisticated enough to be effected by such a small change in resistence. You should be fine. just make sure that your connections are solid
              Yes you can lengthen the harness. Make sure you solder and heat shrink all of your connections.
