Pressur switch
  • Pressur switch
    Hi,
    My pressure switch got stock today(luckily I was in the car and could cut the power off the compressor). Does any one know a new good one to buy??
    Www.vts-racing.no
    what pressure does it cut on and off at? I have a few.
    also, you may want to pull yours and see if it has rust and simply clean it out....
    orrrr, you could send me your money
    *~* Yamaguchi-gumi Syndicate Member #59,005 *~*
    // Bippu-Car \\
      Any viair press switch is good, they are expensive either....
        I couldn't see any rust. I live in Norway and the temperature jumps up and like a yoyo. So
        moisture is probably the problem.
        Www.vts-racing.no
          They looked good!!
          Www.vts-racing.no
            If moisture is an issue I have 2 recommendations.
            1) Run at least one air dryer, further away from the tank is better so the air has time to cool.
            2) Is your switch mounted in/around the bottom of your tank? If so Relocate it somewhere where the chances of it getting moisture in it are slim.
            Lolvo build thread.
              What type of management are you running?
                I've relocated it. I think I have to put on an air dryer.
                Www.vts-racing.no
                  AZ pro 250 compressor, 20L tank and the vales I'm not shure who made them.
                  Www.vts-racing.no
                    Ah okay, wasn't sure if you needed a digital one or not. They all work pretty well but like Oxer said, Viair's are a safe bet.
