Well regrettably, the time has come to have to sell my e30. In a way it pisses me off to have to do this but shit happens what can i say. So on to the stuff u actually wanna know.
Make: BMW
Model: 325i sedan, Alpine white
Miles: 170k on the chassis
Engine: 92 Non-vanos M50 from a 325is w/ 92k on the clock.
The donor car was very well maintained at the dealer only. I did all general maintenance to the engine prior to install.
New: T-stat, valve cover gasket, oil pan gasket, oil pump nut was lock tightened in place so no fear of it backing off. NGK plugs, headers, aluminum T-stat housing, belts, engine mounts, tranny mounts, 2.5" exhaust, walker 2.5" high flow cat, borla muffler, brand new O2 sensor, 2200 CFM auxiliary fan (mounted not wired) Brand new IS lip with all new mounting hardware. Full ground control coilover setup with dampening adjustable Koni's and front camber plates. I'm sure theres more i just cant think of it all.
The car has a few small issues, it has a few small dents here and there but nothing a paintless dent guy cant do. No rust...the heat does not work as one of the heater core lines was busted during the swap. I have a new heater core and blower motor and blower motor cover to replace the damaged ones. These will be included with the car. It will need a new Guibo as it is starting to see it's better days, this part can be had pritty cheap from any bmw online parts site. It also comes with another e21 brake booster. the one that was in it was not shortened enough so i got another to replace it. It is already modified jsut needs installed, which would take about 15 minutes since the heater core needs replaced anyway.
The interior with the exception of the seats is in good shape...the driver seat is frayed and the passenger seat is starting to. The back seat at the very top is starting to do the same from sun wear. I can provide damn near brand new Black Recaro SE seats for an extra 500. Also have mint black door pulls and map pockets. I was going to do black seats and black door pulls for a two tone black/blue interior. The car was heading in the direction of being used for auto-cross so i was not so worried about the interior. A few small things and this car would be ready to toss on a track and tear it up.
I do not have many pics but will take as many as requested or required. You may also come by and check the car out if you so desire.
Here are the few that i have as of now.
Special thanks to Chad for such a good pic.
http://s646.photobucket.com/albums/u...t=SDC10602.flv
$3800, OBO
Im only asking for what i have in the engine swap and coilovers.
I'm open to making deals as i am sure most of you already know. Trades, trades + cash, or just cash is always great.....;D
Make: BMW
$3800, OBO
