I've always used teflon tape but its been a hit or miss in getting a perfect seal. what are the other options that work for some of you?
best thread sealant?
This topic is closed.
Not for NPT joints. If it leaks and it's NPT it likely isn't tight enough.
http://www.oreillyauto.com/site/c/de...0802&ppt=C0137
We use thread tape for all of our setups without any leak problems. If it leaks, do it again but if you hold the NPT side of the fitting closest to you, three clockwise wraps should do just fine.
Just a heads up. All NPT is tapered so don't over tighten the fittings because they could start to mess up threads in the tank or whatever the fitting is going into.
I used "leak lock". Its used at my work for sealing threads on a/c systems where the particles are smaller than air.
im trying loctite 565 this time around, we do stock like 15 different thread sealants here at work tho, i never really had problems before with teflon tape thoMy super boring build http://www.stanceworks.com/forums/sh...other-M3-buildInsta Mintyhinrichs
