Help me on camber on a E46!!
  • Help me on camber on a E46!!
    Hi! im in the way of getting to the stance I want for the bimmer, but the rears are rubbing a little, and in long trips with bad roads, it annoys me a little. Im a noob in this stuff, so i think you can help me.... I just want a little camber in the rear, for looks and stop the rubbing, what are the most used methods for this? at which costs? Thanks!
    adjustable rear control arms will add an extra degree of camber
      thanks man! any more suggestions?
        Apart from adjusting the standard eccentric bolt at the back, and buying camber arms and plates for the front there is no other suggestions.
          If your comfortable adjusting it, there's an eccentric bolt that gives (I think) about 0.5-1 deg of adjustment but in reality is quite a lot if you're only just rubbing
          This is it here, bolt number 10:
          Take it to your alignment shop and ask them to adjust it to give you the maximum camber. They can then adjust your toe to suit.
          Pics!
          *too slow
            thanks guys!
