Noob Question
This topic is closed.
  • Noob Question
    hello
    was thinking about baging my daily, but i still want the rear wheels to poke, is it hard to setup the accuair e-level so the wheels don't tear up my rear fenders when its all the way down?
    -Joakim H
    It's the same as having coilovers in regards to the wheel fitment
      when you park your bagged car you usually lay the frame, but if your rear wheels are poking and you lay frame i will belive the fenders will take the whole lode of the car, or am i wrong, will it stop when it's in contact whit the wheel or something
      -Joakim H
        You'll be okay.
          someone with first hand experience?:P
          -Joakim H
            -Joakim H
            We have the eLevel system on two of our own cars here and honestly you will be completely satisfied with it, it's probably the best setup for daily driving. If you fully dump your car, yes chances are that your fenders can lay on the sidewall/ rim, but it really depends on a lot of factors. Your best option would to to add bump stops to get your car to lay out at your desired height.
              aa thanks, yes i have been on your site, was thinking to get the stuff from you guys
              -Joakim H
                -Joakim H
                  Set your coils to the right height and you will be okay. I was very lucky because my wheels tucked right under my fender.
                    aaah yeah,
                      Are you planning on doing a bag over coil setup?
                        yep, that was the idea, its going on a BMW E46 touring,
                          Okay cool I didn't know that. Yeah like Boxer said, I would just adjust your coils first and then worry about bump stops later which you probably wont even have to mess with.
                            okey
                            thanks guys for the answers
                              I am currently on my stock struts and the seals I think are blown. If you do coils you can get much more travel out of your bag setup. You can go to the ground and also go real high.
