View Full Version : adam's rotors: the famous. the legendary. the world renowned...the best, now on SW!
adamsrotors
02-15-2011, 12:38 PM
BUILD YOUR CUSTOM ORDER | MACHINE PATTERN, ZINC FINISH, HUB COATING, METALLURGY, & BRAKE PAD/STAINLESS STEEL LINE/FLUID PKGS.
WWW.ADAMSROTORS.COM (http://WWW.ADAMSROTORS.COM)
adam's rotors inc. started out small and remains that way...a tight knit, self-owned & operated company established & going strong since 2006.
the small outfit and one-on-one interaction creates only the best service w/quick response & even faster made-to-order set-ups. with top notch products, this lends hand to our success thus far.
working 24/7 throughout the day, any and all questions are answered within the hour to the best of our ability, if not instantly.
being an online company we do business direct via email, instant message, PM, and over the web in our ever growing threads...we're always here ready to reply!
we are a fully made-to-order, replacement disc brake, rotor manufacturer...we offer only factory fit, OE spec, plug n' play discs.
http://i339.photobucket.com/albums/n455/remembertofocus/Screen20Shot202015-04-1720at2010.18.5420AM20copy_zpskcxkcfl7.jpg (http://www.adamsrotors.com)
WE CATER TO THE CAR ENTHUSIAST WHO NOT ONLY NEEDS NEW BRAKE ROTORS, BUT WANTS SOMETHING DIFFERENT BEHIND A NICE SET OF WHEELS.
be it looks or performance, adam's rotors is the only company to bring you over 17+ machine pattern variations (most of which are exclusive to AR), 3 zinc finish offerings, and 5 ceramic-silica hub coating options.
YOU PICK, WHAT YOU WANT AT AN ALL-INCLUSIVE PRICE | COMPLIMENTARY CORROSION PREVENTION, FREE SHIPPING, CHOICE OF DRILLING, SLOTTING, AND/OR DIMPLING (http://www.adamsrotors.com/gallery/gallery_detail.aspx?gallery_cat_id=1&gallery_id=2), ALL LOADED INTO OUR WEBSTORE (http://www.adamsrotors.com).
adam's rotors expertise is in the VW/audi market, but do set-ups for ANY make/models car/truck/van…check to our store!
http://i339.photobucket.com/albums/n455/remembertofocus/racedetail_zps9haddhz3.jpg (http://www.adamsrotors.com/)
WHY ADAM’S ROTORS? WE’RE DIFFERENT!
because we do what no one else does. AR is a customizable product, having managed to turn a boring replacement product into something different. it's a have-it-your-way, made-to-order modification item ideal for any enthusiast. now, instead of just picking 1 of 1-3 drilled or slotted rotor styles from off-the-shelf inventory, we offer over 17+ patterns for your choice/taste, how YOU want them. after that pick a zinc for corrosion prevention...silver? gold? maybe black? thereafter you can even add one of our coated hub colors in a satin ceramic finish to finalize your set and truly give them polished, unique look. we now even offer upgraded metallurgy, to a stronger premium grade high carbon iron if you so wish. we at AR believe a rotor ISN'T just a plain ol' service part...rather a fun, custom, cool way to not only enhance the look of your car, but add performance, protection, and something different to your build, with a ton of bang for your buck!
oh yeh...and they actually perform!!!
track tested, endurance race team approved; check it out HERE (http://nickscarblog.com/reviews/adams-rotors-race-tested-audi-style-approved).
http://i339.photobucket.com/albums/n455/remembertofocus/streetdetail_zpskwdioumr.jpg (http://www.adamsrotors.com/)
QUALITY, IT'S ALL IN THE DETAILS...
we chamfer each drill hole and pay extreme attention to how we lay down our machining…taking meticulous measures to avoid each and every vent rib; the internal cooling veins in most modern vented brake rotors. AR will not drill a rotor we are unable to do so with and thus unlike most, never have issues. this is another reason why unlike many, we also offer dimples and unique slot patterns, ways of avoiding this and offering better, longer lasting, quality products when we see possible issues with venting. lastly each set is made for YOU without the limitations of pattern & finish pre-made, “in stock”, off-the-shelf parts have. instead, we start each order upon payment & cater to your needs/wants for your car.
HOW IT WORKS: (http://www.adamsrotors.com/info)these are customized by you & made per order; you'll have them in about 2-3 weeks...
(this takes in account ordering raw material, ship time to the shop, pattern machining, zinc finishing, hub coating & curing, packaging, & shipment pick-up!)
we hold NO inventory & are held to the same final sale terms as our policy.
we make ONLY factory fit replacement rotors to OE spec. plug n' play original fitment.
whatever one-off size you may be after other than what your car came with, will need to be based off another application's rotor that already exists.
in some cases, we can open up hub bore and modify bolt-patterns (within reason) but we need to discuss via email, first.
YOU TELL US HOW YOU WANT THEM!
dimpled
drilled
slotted
dimpled/slotted
drilled/slotted
dimple/dimple/slot
drill/drill/slot
AR race (exclusive double slot)
AR street (exclusive double slot/drill)
AR track (exclusive double slot/dimple)
AR sport I (exclusive over-dimple)
AR sport II (exclusive over-slot)
AR speed (exclusive multi-slot)
AR dift I (exclusive triple curve)
AR drift II (exclusive triple curve/slot)
AR drag I (exclusive cross-hatch/slot)
AR drag II (exclusive cross-hatch/double slot)
silver zinc, for brilliant rust-free finish is STANDARD on all orders, is a corrosion prevention process/measure, BUT...
*COLORED ZINC FINISH:
gold zinc or black zinc finishes are a subtle, unique, aesthetic touch for your rotors, very few offer!
also...
*HUBS COATINGS:
this gives the rotor a nice clean, tailored, finished look.
the rotor is still standard silver zinc dipped, with a high temp, satin, ceramic-silica finish.
available in 5 colors…we can do some custom colors, so let us know what you need/want.
or
*G4000 HIGH CARBON IRON METTALURGY UPGRADE:
we have started to offer a premium grade cast iron option, available for most all applications.
standard grade G3000 is great and more than sufficient for most any use, but in some scenario's, a stronger iron is beneficial.
reports of longer lasting rotors have been found, ideal for high mileage cars, haulers, or even heavy track goers who really beat up their brakes.
it also greatly reduces the worry of pad squeal in cases of high friction with high performance brake pads.
the harder iron is stronger and fights warping and cracking concerns, and higher carbon & chromium levels aid in oxidation resistance.
another great benefit to the G4000 upgrade, is the price includes a premium black coating on the rotor at no charge.
WWW.ADAMSROTORS.COM (http://www.adamsrotors.com)
(http://www.adamsrotors.com)ONE (1) YEAR exchange warranty for:
manufacture defects (cracking) per rotor...on all orders!!!
EVERY ORDERS IS FINAL-SALE, ONCE PROCESSED | NO EXCEPTIONS.
again, we hold NO inventory & are held to the same final sale terms as our policy.
if there is EVER any issue with fitment/error on OUR end, we will ALWAYS make it right!
AR EXCLUSIVES- (http://www.adamsrotors.com)
[/URL]
AR drift I [triple curve] & [U]AR drift II [triple curve/slot]:
(http://www.adamsrotors.com)http://i339.photobucket.com/albums/n455/remembertofocus/drift_zpscsh6puap.jpg
[must be ordered with coated hubs]
AR drag I [cross-hatch/slot] & AR drag II [cross-hatch/double slot]: (http://www.adamsrotors.com)
http://i339.photobucket.com/albums/n455/remembertofocus/drag_zpsxfdflrjj.jpg
AR speed [multi-slot] & AR track [double slot/dimple]:
http://i339.photobucket.com/albums/n455/remembertofocus/speed-1_zpslxwbwjn1.jpg
AR sport I [over-dimple] & AR sport II [over-slot]:
http://i339.photobucket.com/albums/n455/remembertofocus/sport_zpsprnomse1.jpg
AR race [double slot] & AR street [double slot/drill]:
http://i339.photobucket.com/albums/n455/remembertofocus/race_zpsaawoca1m.jpg
Jedidiah
02-15-2011, 01:05 PM
We couldn't be more excited to have adam's rotors on board. While we aren't the most "performance" oriented car forum, we certainly can say we drive the piss out of our cars. Whether it be distance driving or just having older vehicles, at some point rotors need replacing.
Adam has created a great niche in not merely providing replacement rotors, but high quality replacements with bespoke options allowing you, the customer, to individualize your order.
On top of that, you will be hard pressed to find someone more responsive then Adam. He prides himself on his customer service, and I can fully see why.
Expect big things this year from adam's rotors.
adamsrotors
02-15-2011, 01:14 PM
so do we Ben, so do we...happy to be here.
hinrichs
02-15-2011, 01:24 PM
Ill be sending an email for a quote, dont need brakes yet but id like to try out your rotors instead of what is already available for my car which is kind of limited without going to a bbk
Mattphi
02-15-2011, 01:26 PM
+1. Would you be able to make a setup for a Volvo platform?
adamsrotors
02-15-2011, 01:30 PM
of course...
chevy trucks, jaguar sedans, honda hatch backs...nothing is a match for us!
let us know guys.
adamsrotors
06-01-2011, 06:20 PM
great start to a new month!
we're honored to have our S8 and company featured by Audizine.
full article & photo set HERE (http://www.audizine.com/features/article.php?tid=19) and company video spotlight here:
http://www.audizine.com/images/featured/19_tuner_image_1306878933.jpg (http://www.youtube.com/watch?v=KTNQj3I4HGs&feature=youtu.be&hd=1)
[youtube (http://www.youtube.com/watch?v=KTNQj3I4HGs&feature=youtu.be&hd=1)]
adamsrotors
07-18-2011, 04:25 PM
if you're on facebook (http://www.facebook.com/adamsrotors), be sure to FAN (http://www.facebook.com/adamsrotors) us & keep up with the happenings at AR, alot going on!
adamsrotors
08-10-2011, 05:39 PM
AR merch...spread the love and rep adam's rotors everywhere!
AR hoody color way #1: red/white/black
AR's first clothing production and we're jumping right in with cut & sew.
true craftsmanship w/old school flare. expect nothing less from us...fully made to order, just like our rotors
http://i339.photobucket.com/albums/n455/remembertofocus/DSCF0787.jpg
AR hoody color way #2: white/red/black
hand made, real deal 3 layer chenille patch work, hand stitched to a heather grey zip-up american apparel hooded sweatshirt in XS-XL.
...like nothing else out there
http://i339.photobucket.com/albums/n455/remembertofocus/DSCF0800.jpg
adamsrotors
09-13-2011, 05:36 PM
be sure to check out our AR braking BBK's (http://www.audizine.com/forum/showthread.php/436215-AR-braking-BBK-big-brake-kits-by-adam-s-rotors-amp-StopTech)...
http://i339.photobucket.com/albums/n455/remembertofocus/ARBBKBZ.jpg
...and AR braking 2-piece rebuild kit's (http://www.audizine.com/forum/showthread.php/406982-AR-braking-rebuilt-big-brake-kits-by-adam-s-rotors).
http://i339.photobucket.com/albums/n455/remembertofocus/DSCF0078wtmk.jpg
the above are some of the different things adam's rotors is doing, with exclusive patterns and unique finishes...options & services unlike anything available!
AR braking: www.adamsrotors.com/BBK & ARbraking@adamsrotors.com
jr@adaptecspeedware
09-13-2011, 07:51 PM
Looking real good!
adamsrotors
10-10-2011, 04:48 PM
how's things SW?
adamsrotors
10-24-2011, 07:40 PM
we're nearing 2000 fans on Facebook (http://www.facebook.com/adamsrotors)...fan us if you haven't already!
http://i339.photobucket.com/albums/n455/remembertofocus/ScreenShot2011-10-24at43220PM.png (http://www.facebook.com/adamsrotors)
adamsrotors
11-03-2011, 01:23 PM
Fourtitude's TTS-SF project is almost wrapped up and webisode 12 of the build is live and all about brakes!
we built a killer pair of rear Brembo Type-3 pattern-match rotors for the car, using AR's unique, custom pattern-match program:
http://i339.photobucket.com/albums/n455/remembertofocus/type3.jpg (http://www.adamsrotors.com/tag/pattern-match/)
be sure to click HERE (http://forums.fourtitude.com/entry.php?765-Project-TTS-SF-Part-12-Braking-News) for the post, and watch the sweet video as well...
http://www.fourtitude.com/gallery/albums//Features/Project%20Cars/Project%20TTS:SF/12%20Brembo%20Brakes/011.jpg (http://forums.fourtitude.com/entry.php?765-Project-TTS-SF-Part-12-Braking-News)
adamsrotors
12-01-2011, 02:07 PM
been busy working on our latest project...
if you aren't a fan of us on Facebook (http://www.facebook.com/adamsrotors) or follow us on Twitter (https://twitter.com/adamsrotors), Instagram, or Tumblr (http://adamsrotors.tumblr.com/), here's some teasers:
http://i339.photobucket.com/albums/n455/remembertofocus/DSCF0164-1.jpg
http://i339.photobucket.com/albums/n455/remembertofocus/DSCF0174-1.jpg
http://i339.photobucket.com/albums/n455/remembertofocus/DSCF0178-1.jpg
http://i339.photobucket.com/albums/n455/remembertofocus/DSCF0199-1.jpg
adamsrotors
02-01-2012, 01:17 PM
how's your 2012 going?
we're very busy over here!
adamsrotors
02-14-2012, 12:36 PM
happy v-day...
screw the chocolate & roses, order up a fresh set of stoppers and show your lover you care about safety, looks, AND performance!
adamsrotors
03-07-2012, 11:00 AM
we're working on 4-5 potential new patterns to be released the 2nd quarter of 2012...stay tuned!
adamsrotors
03-22-2012, 07:39 PM
adam's rotors featured in this month's eurotuner magazine's Project Silverstone build using AR race rotors!
http://i339.photobucket.com/albums/n455/remembertofocus/ETscan.png
adamsrotors
04-04-2012, 01:56 PM
who doesn't have Facebook nowadays?
be sure to visit our PAGE (http://www.facebook.com/adamsrotors) and LIKE (http://www.facebook.com/adamsrotors) us!
we're ALWAYS posting up news, specials, product, and customer photos on a daily basis.
spread the love and share with your friends, we're nearing 3,000 fans!
http://i339.photobucket.com/albums/n455/remembertofocus/ScreenShot2012-04-04at104527AM.png (http://www.facebook.com/adamsrotors)
adamsrotors
06-01-2012, 11:44 AM
click HERE (http://www.youtube.com/watch?v=03X-chwZOI4&feature=youtu.be&hd=1) for the killer video Audizine did on ROTORS4 (http://www.youtube.com/watch?v=03X-chwZOI4&feature=youtu.be&hd=1)!
adamsrotors
08-08-2012, 06:50 PM
just hit 3000 facebook fans (http://www.facebook.com/adamsrotors)...
join us on FB if you haven't already!
adamsrotors
08-17-2012, 04:27 PM
we're proud to announce our latest release & 13th pattern is now available: AR speed, multi-slot
http://i339.photobucket.com/albums/n455/remembertofocus/ARSPEED.png
[must be ordered w/coated hubs]
ORDER NOW!!! (http://www.adamsrotors.com/store)
shmoo shoe
09-27-2012, 09:53 AM
more pictures of the porsche in post #16? and have you featured or made any rotors for le 3000gt? pictures?
adamsrotors
09-27-2012, 09:58 AM
yes & yes: www.adamsrotors.com
shmoo shoe
09-29-2012, 02:45 AM
thank you sir, but i didn't manage to find any pictures on your website.
_isiah
adamsrotors
09-29-2012, 02:59 AM
^ I assure you it is...
...or simply check my signature?
feel free to email us too.
adamsrotors
10-09-2012, 05:16 PM
customers/users/fans of AR really mean everything to us...and surprise feedback like this is invaluable.
Nick from Nick's Car Blog review:
http://nickscarblog.com/wp-content/uploads/2012/10/IMG_4355-580x414.jpg
(http://nickscarblog.com/cars/adams-rotors-photos-review/)
we appreciate the thought & effort put into composing this and hope others can use this info to help them make their own decisions w/a future purchase of our rotors.
enjoy the read!
-a
alexlandinoyo
10-11-2012, 04:51 PM
about how much does a set of 4 rotors for a 99 lexus ls400 cost? I went on your site to check it out and I really just didnt know forsure if pricing was right... 425 rotors with stainless lines and pads?
adamsrotors
10-12-2012, 10:56 AM
no. but please use the website...
if no price is shown, do as it asks and "CONTINUE FOR PRICING"
this will then send us a quote request which will help us add pricing to our online catalog and get you an accurate quote.
thanks!
-a
alexlandinoyo
10-15-2012, 09:56 AM
thanks!
-a
I figured, I was just thinking it was too good to be true haha. Thank you.
adamsrotors
07-02-2013, 04:43 PM
what a past few weeks it's been, but we're officially moved into our new office!
emails & calls filtered as usual, we're always in contact...let us know what you need.
also we're loving our new webstore:
http://i339.photobucket.com/albums/n455/remembertofocus/ScreenShot2013-06-11at41723PM_zpsd08f164f.png
(WWW.ADAMSROTORS.COM)
WWW.ADAMSROTORS.COM
after selecting your vehicle from the drop-down menus on ANY page, you enter the store & can start building your order as easy as that!
if your particular application has no pricing loaded as of yet, don't worry; send us a quote request on the page to follow...we'll reply w/pricing AND update our database for you!
...we do rotors for ANY and ALL make/model car or truck.
adamsrotors
07-16-2013, 07:34 PM
just bought a new project car last night...we're excited to get started on it!
first addition will be a set of AR sport II's in black zinc...our personal favorite.
adamsrotors
08-22-2013, 01:45 PM
our latest build, the TDI, just got laced up with a set of black zinc sport II's...more soon:
http://i339.photobucket.com/albums/n455/remembertofocus/IMG_1587_zpscced0c4f.jpg
Cavi Mike
05-07-2014, 02:02 AM
I think you need to add a swept slot pattern similar to the Alcon WRC rotors.
http://www.subaruwrcspares.com/resources/_wsb_434x389_Alcon+Tar+FR+Brake+2.jpg
adamsrotors
05-07-2014, 02:10 PM
^ for our pattern-match program sure, email us.
but for normal line-up? no...there is no point/no benefit. there's a reason why our patterns all use straight slots.
adamsrotors
05-19-2014, 09:46 PM
happy monday everyone.
it's been a while posting here...head down filling orders, answering inquires, and taking names!
thanks for all the continued support on these boards.
-a
adamsrotors
06-04-2014, 03:30 PM
let's admire those rotors!
we're proud to be apart of one of the recent StanceWorks (http://www.stanceworks.com/2014/05/jeremys-bagged-bmw-e38-740il/) features, having built a set of Brembo, pattern-match rears for the this 7.
more on our program here: www.adamsrotors.com/PMP with a link to the feature above.
http://stancewords.stanceworks.netdna-cdn.com/wp-content/uploads/2014/05/stanceworks-works-wheels-bmw-e38.jpg
http://stancewords.stanceworks.netdna-cdn.com/wp-content/uploads/2014/05/stanceworks-bagged-bmw-e38-740il.jpg
Khalil
06-06-2014, 12:34 AM
Jeremy's rotors came out super sick.
I've been meaning to get a set for my E36M, might have to check your stuff out then since he was stoked with his.
adamsrotors
07-15-2014, 04:06 PM
www.instagram.com/adamsrotors
www.twitter.com/adamsrotors
www.pintrest.com/adamsrotors
adamsrotors
08-01-2014, 03:21 PM
over 2 years ago, Adam worked closely with a small letterpress company to design his personal business card image.
the design is entirely his concept, put into reality by an old-timey hand crafted plate maker, Fortress LP, using the original techniques of letterpress printing from the early 1900's.
the end result is very much Adam's personal style and was a huge hit once completed...
after years of people asking and a design worth using, we've finally decided to press out some AR shirts.
we'll be using a top quality, standard fit, heavy cotton black T-shirt with white screening on the chest, big front & center.
it will be tagless, including a custom AR logo & size image on the inside neck as well.
these are pressed out of a high quality studio in Southern California who does many of the surf & skate brands up and down the state.
here's a sample of the image itself...
http://i339.photobucket.com/albums/n455/remembertofocus/CARDLOGO_zpsb188860d.png
once the shirts are finished and delivered to the shop, we will shoot them on a model and get them added to the store.
we are taking pre-orders now if you want to lock yours down as a part of the first run...it's a small starter batch for family, friends, and loyal customers; so act now to lock one down.
we will be doing more to come, eventually in white and maybe some tank tops as well.
they will be available in S, M, L, XL, and XXL for $30 shipped USPS priority, within the US.
email/PayPal for pre-sale: orders@adamsrotors.com
adamsrotors
08-21-2014, 02:00 PM
we're live! $28 shipped USPS priority within the US & APOs.
heavy weight cotton crew neck T's with a great classic fit. white screen on black, tagless w/AR logo inner label. they're on the site now.
visit the merch page found on the tab bar or simply add one to your rotor order when checking out.
limited first run...first-come, first serve in S | M | L | XL | XXL
www.adamsrotors.com/merch
http://i339.photobucket.com/albums/n455/remembertofocus/APW_10221_zpsd6071789.jpg
http://i339.photobucket.com/albums/n455/remembertofocus/APW_1025_zps90de0b52.jpg
adamsrotors
09-04-2014, 03:31 PM
thanks for all the support here...
grab yourself a t-shirt if you haven't already!
adamsrotors
09-29-2014, 02:07 PM
September has been a great month...we appreciate all the inquires & orders.
we're always available via email, so let us know what you need: sales@adamsrotors.com
adamsrotors
11-05-2014, 01:37 PM
it's almost that time of year again!!!
adamsrotors
09-30-2015, 04:32 PM
just updated the OP with all our new options...please visit our website when you have a chance!
adamsrotors
12-03-2015, 02:53 PM
hope everyone had a great thanksgiving...we're looking forward to christmas.
adamsrotors
12-10-2015, 05:47 PM
just a reminder to visit our new merch page...we offer koozies, t-shirts, and our super cool tri-color sticker packs!
http://i339.photobucket.com/albums/n455/remembertofocus/APW_1409%201_zpshq7qnqmr.jpg
adamsrotors
01-05-2016, 02:53 PM
[LIMITED: made only for Adam's close friends & family for Christmas 2015. we have a small batch left, we've decided to offer to our loyal, supporting customers, while inventory lasts]
http://i339.photobucket.com/albums/n455/remembertofocus/IMG_1009_zpstwtliww8.gif
(www.adamsrotors.com/MERCH)
these are top quality custom generated, laser cut & etched, wood coasters; designed exactly to spec of 6 of our exclusive patterns. the lug holes & hub bores are cut thru, along with accurate slotting, dimpling, drilling, and AR's chamfered edges. they are sturdy, absorbent, 3/16" thick coasters, in 3.9" diameter Basswood. these are solid wood, not laminated, which can handle water/moisture making them great, usable drink holders. the set of 6 coasters come in a tin w/unique label design. stack the set on the lid and it can also be used to display the coasters on your desk or coffee table.
SHOP NOW: www.adamsrotors.com/MERCH
*place order this month & receive an unreleased version of our AR sticker, with your set*
the 6 patterns included are:
AR sport I, AR sport II, AR speed, AR drift II, AR drag II, & AR street/track
adamsrotors
01-11-2016, 07:11 PM
http://i339.photobucket.com/albums/n455/remembertofocus/APW_4048_zps246c7vdn.jpg
adamsrotors
01-18-2016, 07:45 PM
http://i339.photobucket.com/albums/n455/remembertofocus/rotors_zpsytfvyyk8.png
adamsrotors
04-26-2016, 01:17 PM
AR mobile wallpaper:
http://i339.photobucket.com/albums/n455/remembertofocus/illusion-black-and-white-to-color-wallpaper-1-2_zpsb2y4x31j.jpg
