just picked up some new wheels and the specs are
front
16x11 inner lip and 12 form outers measured the backspacing laying a straight edge across the back of the wheel and found them to have a 5 inch backspacing. since the rolled portion of the lips is 1/2 inch each this would put the calculated backspacing at 4.5 inches and an offset of -25.4mm or - 1 inch of backspacing seem right?
rears are 16x12 inner bead to bead and 13 outer measurement. wheels have a 5 inch from hub to straight edge. again 4.5 inch calculated backspacing with an offset of -38.1mm or -1.5 inch backspacing
figures seem about right?
i used (width/2) - backspacing = offset
front
