need help: maximize buddy club n+ coilover
  • need help: maximize buddy club n+ coilover
    hi, i have problem with my newly installed buddy club n+ coilover
    the problem is my car didnt want to go low, but my front spring is already low,
    and then i found this gold tube and the mounting
    what should i do?
    should i adjust the mounting (black one) until it closing the gold tube to go super low, or i should raise it up...
    Originally posted by luke318is
    I just spent 2 hrs on a plane from Ibiza to Barcelona, then drove 23hrs straight home
    now I'm ready to slip into a slight coma, so PM me, and we'll get things sorted
    Well, logic would answer the question, but yes, you should raise the black bracket up the damper as high as possible without compressing the spring. You could remove the lower red collar to get more drop.
    If the damper is going to hit the axle, you can lower the spring perch instead.
      you can remove the red, and adjust the gold.
      Yellow Frame Club
      member 01
