I would like to know this also.
New to the site, trying to sell my MB 190 so i can get a E28.
Anybody know sumthing about custom supensions? Like make coils from another car fit or sumthing?
really the lowest setup would be the ireland engineering coil over idea. threaded bodies on billy sports revalved to spec and h&r race springs, they usualy go with a 7 or 8 inch spring but h&r makes like 5 and 6 inch springs in very high spring rates to go along with helper springs just dont get helper springs..., if you simply revalved your billys to match the high spring rate of the short springs youd be strait. and have a stiff as shit car that wont bottom out and still act right over most bumps. the e28 suspension is plenty robust to handle it but your oil pan will have a death sentence. rear camber/toe correction and a set of front camber/caster plates and your car could still handle like its supposed to. if you run bags like spasticdwarf on track performance is probably shit.
i think youd be running like 550+ pound springs they come in 25lbs increments but the shorter ones are higher rates. dont go with the 3 or 4 inch springs they are helper springs.. given the amount of money involved in a setup like this ireland should be more then happy to help you.
ground control uses koni shocks and their ebiach springs, i cannot see ground control being able to get a super slammed setup with adequate dampening with koni's and they still with have longer springs. but ground control is plenty low to trash your oil pan in short order and get stuck on speed bumps.
UPDATE: im saying this because i **** koni shocks after experiencing the wonders of correctly valved billy shocks, koni's can do the same but only after rebuilding and THEN shock dyno testing to note realistic adjuster settings and possibal rebuilding again when you find out the (shock not ride height) adjusters are a stupid idea. ground control's setup does not work with billy shocks but Ireland engineering's do. same thing just a slightly diffrent front spring perch setup.
and i didnt know ground control would sell you shorter springs, still 4 inch spring on koni shocks with stock travel?........
Sooo....that made no sense to me at all, but thanks for the effort. I did sum reading, and the front supsension is a McPherson setup, so it must be possible to make coils from another car fit.
For the rear i think i gonna go with cut springs and sum sort of bumpstops. Not gonna be a high performance machine, just a ultra low cruzer..
spasticdwarf ran and a few other e28 owners are running ground control set-ups and they are slammed to the ground. the trick is to run shorter springs. i'm thinking about going this route here since i really dont see any other way to do it right. good luck.
But ground control costs around $1500, and the i have to pay alot of extra tax to get it to the netherlands.
No one ever thougt of fitting coils from another car up front?
