View Full Version : Compressor broken? Viair 380c
JayDz
06-22-2019, 02:40 PM
Hello everyone,
I have been trying to fix my airride setup for a week, the fuse to the compressor keeps burning out (even tried 40amp).
The compressor (Viair 380c) would run and stop when it reaches the limit (200 psi).
But when I then pump air in the bags and the compressor should turn on the fuse burns out.
Also when I pump the tank to 115~ psi and I turn the compressor off and on the fuse burns out.
I found out the check valve was leaking air back to the compressor, I tought this might have caused the compressor to work too hard and get too hot and that caused the fuse to burn out. So I ordered a new check valve, it does not leak air back so thats good. But the fuse to the compressor still burns out. I also tried to directly connect the compressor to a battery booster (also with a fuse) and it burns out aswell.
When the pressure is low (30 psi~) I can switch the compressor on and off as many times as I want but the fuse never burns.
Does this mean my compressor is broken?
Thanks everyone!
Dear Regards.
autoports
09-07-2019, 12:20 AM
The costs of Creta diesel variations start at Rs. 10.00 lakh and the hyundai creta petrol automatic on road price (https://autoportal.com/newcars/hyundai/creta/onroadprice.html) top-end diesel is valued at Rs. 15.64 lakh. Hyundai Creta is accessible in 17 variations and 9 hues.
