View Full Version : W124 300E manual swaps????
MacMade
10-16-2018, 01:36 PM
Are there any good options for a manual swap for the w124? I hear plenty of M103 190es came with a manual. What about aftermarket.....like tremec? Anyone make a bellhousing to mate them together?
carmaniac37
04-16-2019, 02:33 PM
The 5 speeds out of W201's and W124's are interchangeable. The only attention to pay is on the flywheel to make sure you have the correct timing marks for the engine. M103 needs the three tabs etc... I have a M104 6 cylinder engine bolted to a 5 speed from a 8V 4 cylinder car. Clutch is a smaller diameter on the 8V. Cosworth and 6 cylinder cars have the larger diameter flywheel. Otherwise you just need the front half of the driveshaft from the doner car, pedal assembly with master cylinder, clutch lines, and to jump the neutral safety switch.
GloriaFl
05-13-2020, 12:03 PM
I support you
andi1999
12-08-2020, 12:03 PM
Help in assignment (https://ca.payforessay.net/assignment) is the best option not only to save a lot of free time, but also to increase your grades. For example, I've been using this service for more than a year now and during this period my grades have increased very much.
