FS: 98 Passat Slammed on KWs
  • FS: 98 Passat Slammed on KWs
    $3800 obo
    201k
    KW v1 Coilovers
    OEM Mercedes SL500 wheels 18x8.5/9.5
    Whole front suspension redone, new tie rods, control arms, cv boots, everything
    Timing belt, Waterpump and housing, pulleys, pcv system, TIP, and intercooler piping all replaced 600 miles ago.
    Audi a8 brake upgrade about 3k ago, cross drilled and slotted rotors
    Full fluid flush and change (brake (also all flex brake lines), coolant, etc.) 3k ago (coolant with the timing obviously)
    OEM HID reps with bi xenon
    Cons:
    MAF is shot, runs fine without just idles a bit funny if you cut the wheel all the way to the right or left.
    Drivers front fender has a small dent from towing and the wheel well area is a bit worn.
    Exhaust exits under the car midway but I have the full stock exhaust to go with the car
    Car has rear leather and front cloth (havnt finished the swap)
    Car will come with parts I have for it (extra water pumps, original headlights, etc.)
    I am located in Hermitage, PA where rt80 and rt376 intersect. Call or text anytime at 724-813-2023 my name is Richard. If I dont answer leave me a voicemail I will respond when I get a chance.
