looks like all you need now is bags. and i think you can run the bags on your racelands in the front and then get a bag and adapter plate for the rear.
yeah you still need bags...aerosports for the fronts and then you have a few options for the rears, if its like the E46 it seemed like my jetta back there, like anonymous said you just need some brackets for those
That kit is SOOOOO bare bones, never really liked it ever since it came out. A 5 gallon tank with a single 380 compressor will take forever to fill. I personally think you're better off piecing together your own setup and after it's all said and done, that will probably cost around the same or less for everything and have better components
Don't even waste your money on some choncy ass kit like that! Paddle valves... No thank you. Spand a couple extra hundred dollars and do it right the first time. I know ts quite a bit more, but this is the system I am running ->Digital<- but you can do something in between for an in between price.
If you do mind manual paddle valves theres a cheaper way to peice together a kit because you have to replace all of the fittings given to you in that kit. trust me i got the same one...
I dont have any pics of it, but I am running UAS Aerosport bags up front, using their bracket kit, But for the air management it is all mounted in the spare tire well, This is the digital system I am using
75% of issues with air ride are from the install. Of course there are failure rates of components just like anything else. But faulty wiring or the placement of fragile components (ie air line) are the usual cause of air ride "issues"
I was just talking to Kielan about throwing bags on my e36 last night lol. I was looking at the same kit but on bagriders.com. I would add a extra compressor like aaron said. That kid plus extras (another compressor, water trap, ect) would be around $800 without bags.
