E30 modified strut tube
  • E30 modified strut tube
    Quick question, how much do you usually cut out off of the strut?
    What insert are ou using? GC typically does 1 inch i believe, but you can do more.
    Flickr
      Yeah, cause if your running a regular strut, your gana run out of travel fast. Tokico, Bilstien, Koni and KYB all make a short stroke strut.
        1 to 2 inch's is normal. trust me with 2 inch's cut out and ground controls u can lay a e30 on the ground.
